STOCK SLEEPER BIGSTUFF3 IROC FOR SALE
Car: 88 iroc
HERE IS MY CAR FOR SALE.
THE CAR IS A 1988 IROC-Z. BLACK ON BLACK T-TOP CAR. THE CAR IS ALL STOCK ON THE INSIDE AND OUT. I RESTORED THE CAR A COUPLE YEARS AGO. ALL BODY PARTS AND WEATHERSTRIPPING WERE BOUGHT AT GM. NO AFTERMARKET JUNK. THE CAR IS A SLEEPER THAT RUNS ON PUMP GAS. THE ONLY THING THE CAR NEEDS IS A ROLL CAGE.THERE IS TOO MUCH LIST. ANY QUESTIONS I WILL ANSWER FOR A SERIOUS BUYER. HERE IS A BASIC BREAK DOWN OF THE CAR.
BLOCK 400 .030 EAGLE CRANK 3.75 STROKE 6 INCH EAGLE H BEAM RODS SRP 10.6 FLAT TOP PISTONS
HEADS: AFR FULLY PORT HEADS. HEADS WERE PORT AT PORT PROS IN TEXAS. HEADS FLOW 298 AT .650 INTAKE 223 ON THE EXHAUST. I HAVE THE FLOW FOR BEFORE AND AFTER. 2.05 INTAKE 1.60 EXHAUST FERREA 6000 VALVES. TITANIUM RETAINERS. JESEL SHAFT MOUNTED ROCKERS. MANTON 3/8 PUSHRODS.
INTAKE: ACCEL PRORAM FULLY PORTED INTAKE. WILSON TB 1136 CFM WILSON 100 DEGREE INTAKE ELBOW. 55 LPH INJECTORS. WILSON NITROUS SPRAY BARS MACHINED INTO ELBOW. I DID THIS SO THE SETUP WOULD FIT UNDER A STOCK HOOD
EXHAUST: HOOKER SUPER COMP FULL LENGTH HEADERS. CUSTOM 3 INCH Y-PIPE TO A 4 INCH MUFFEX EXHAUST SYSTEM.
TRANS: FULLY BUILT TURBO 400 WITH TRANS BRAKE. CUSTOM PTC TORQUE CONVERTER.
REAR END: STRANGE 12 BOLT 3.91 RATIO UPGRADED 33 AXLES AND POSI UNIT AND READ END COVER
ENGINE MANAGEMENT: BIGSTUFF3 SYSTEM WITH INTERNAL DATALOGGER. MSD DUAL PICKUP DISTRIBUTOR(CRANK AND CAM PICKUP).
COOLING: GRIFFIN 1.25 TWO ROW RADIATOR WITH TWO SPAL FANS (MOUNTED FROM GRIFFIN).
BRAKES: FRONT: WILWOOD 4 PISTON CALIPERS 12.19 TWO PIECE ROTORS. REAR. 93-97 CAMARO DISK BRAKES
RIMS: I HAVE TWO SETS OF RIMS FOR THE CAR.
STOCK CHROME 16INCH IROC RIMS FOR THE STREET.
2 HOLESHOT 15X3.5 PENTA STAR. 15X8 WELD PROSTARS WITH 28X10 SLICKS
THAT IS THE RUN DOWN OF THE CAR. I PUT THE CAR TOGETHER MYSELF. I HAD LARRY AT ASSC RACING IN CHICAGO TUNE THE CAR ON THE STREET AND AT THE TRACK. THE CAR RUNS ON PUMP GAS. I WILL GIVE ET FOR CAR TO THE BUYER. I ALSO WILL BE AVAILABLE TO THE BUYER ANYIME THERE IS A QUESTION WITH THE CAR. ANY OTHER QUESTIONS I WILL ANSWER TO A SERIOUS BUYERS. I PREFER TO DO IT ON THE PHONE. JUST PM SO I CAN GET A HOLD OF YOU. YOU WILL NOT BE DISAPPOINTED WITH THE CAR. I HAD THE CAR IN THE THIRDGEN FEST 06 AND WON BEST CAMARO.
BEST TIME ON THE CAR. 10.9X AT 123 ON MOTOR (BEST 60 FOOT TIME 1.45). THE CAR IS SETUP FOR NITROUS. I NEVER SPRAYED THE CAR. IT WILL GO 10.0 NO PROBLEM. HIGH 9'S WITH GOOD TUNE-UP.
PICS I WILL EMAIL OUT
PRICE: 17,000 I HAVE OVER 30,000 IN THE CAR. I HAVE ALL RECEIPTS FOR THE CAR
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
Re: STOCK SLEEPER BIGSTUFF3 IROC FOR SALE
how much for the longblock?
Car: 1989 Formula 350
Engine: 350 fuel injected
Axle/Gears: 9 bolt w/370 gears
I would like to get more info on the car, PM your # so I can give you a call.
Car: 1992 Ttop Camaro
Engine: 3.1L v6
what are you asking for the chrome wheels the iroc ones
actually interested in the weels on the car as a roller interested in a trade or give me a price so i know where your at
Car: 88 iroc
mustangman65_79
08-11-2015 03:17 PM
