12inch horn loaded sub build
if u guys didnt see my last build the detials can be found here
https://www.thirdgen.org/forums/car-...pine-type.html
a pair of those played down to 13hz
im not sure what direction im going to go with this build either play as low as possible or as loud as possible
probably as loud as possible
the drivers are some cheap pheonix digital 12's that i picked up for 25 bucks a long time ago right now i have these in a box thats aprox 2.5cft per side with slot ports tuned to 30 or 35 hz , for a cheap sub these things absolutly pound and have tons of excursion
from the specs ive come up with these things should do pretty good in a tapped horn design or even a loaded horn design
im playing with a design right now that should go from 25 to 95 hz and be very efficiant , once i tweak it a lil more ill post up some results and pics
should be later today
Re: 12inch horn loaded sub build
tyeo098
11-30-2015 06:27 PM
