Running an amp to my 6 x 9 s
Old 11-25-2000, 11:10 PM
Paul_Hughes_87 T/A's Avatar
Car: Chrysler 300c
Engine: 5.7L Hemi
Transmission: 5spd auto
Axle/Gears: 2.89
currently i have a sony x-plod deck which claims 50w X 4. i just bought a 100 watt 2 way amp and i was wondering how much of a difference it would make if i ran my prestige 6 X 9 off of the amp instead of the deck
87 trans am
lg4
sony deck
prestige 6 x 9
Old 11-25-2000, 11:14 PM
Topgun's Avatar
None, your amp will deliver 50W X 2 Peak power, same as your Head unit
EMAIL: CTopgun5@aol.com
_______
84' Z28
New 350 Ci 4 Bolt Main with all L69/HO Parts
4 BBl Carb
180º Thermostat
K&N High Flow Filter
700R4 Trans
15X7 Standard Z28 Wheels, With 215/65R15 BF Goodrich Comp T/A HR4 Tires
Charcol in Color
no T-tops, but wish
New Head unit, JVC KD-SX750
New Kenwood 3-Way 6X9's KFC-6906S
New Pioneer Sub TS-W253C
New Jensen 4-Channel Amp XA-4150
As FiremanZ28 says "Friends don't let Friends Drive Mustangs"
Pic of my Z28, thanks to ZZ4 and his web page: Http://www.geocities.com/ukzz4iroc/z28camaro.jpg
Old 11-25-2000, 11:18 PM
Car: Chrysler 300c
Engine: 5.7L Hemi
Axle/Gears: 2.89
you mean running a seperate amp instead of the one in the deck will make no difference at all even though it is an external amp and is running right from the battery?
Old 11-25-2000, 11:24 PM
Topgun's Avatar
Thats right, if it was a higher rated amp, it would make a difference. But they are both rated at 50wX2 (50 Watts Into Each Channel)
_______
84' Z28
4 BBl Carb
180º Thermostat
700R4 Trans
Charcol in Color
no T-tops, but wish
Old 11-25-2000, 11:33 PM
Car: Chrysler 300c
Engine: 5.7L Hemi
Axle/Gears: 2.89
i read on a car audio site that the deck might say its pushing out 50 watts but it is actually pushing out a lower number of watts does anyone know if this is true or bs
Old 11-26-2000, 12:20 AM
85IROCTPI's Avatar
IF that is true (which i'm not in a position to say it is or isn't) then who's to say the amp might be rated at 50 watts x2 and is actually puching 35 x2 ??? huh ???
3rdgen.fbody.com - Leading the F-body into a 5th generation
85 IROC-Z
305 TPI
Bone Stock
Dead for the winter
"Their's nuthing like the sound of a small block chevy and a bass thumping sound system in the morning" - me
Old 11-26-2000, 12:24 AM
Car: Chrysler 300c
Engine: 5.7L Hemi
Axle/Gears: 2.89
the alternator does not send enough power to the head to give it full power for the internal amp
would this happen to a amp connected directely to the battery
Old 11-26-2000, 01:49 AM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
Hook it up,listen to it,and judge for yourself.The external amp is going to have a much larger pwm power supply,transistors,caps,etc. You will have more sonic headroom with the ext. amp than with the deck.Also,is that amp 100w max or 100wrms? The deck is only going to be 50watt max per ch. I can gaurantee that even if the max power rating is the same for both,the amp will have a better continuous rating and better transistors for faster switching speeds and cleaner sound once you start cranking it up(provided that it is a good amp).
RazorN8
01-07-2022 11:44 AM
SPEEDY Z28
08-17-2015 01:46 PM
Irocohio
08-12-2015 08:03 AM
ZsTransAm
08-11-2015 07:30 PM
Quick Reply: Running an amp to my 6 x 9 s
