Blue smoke out the tailpipes - newly rebuilt 355
Old 03-20-2009, 01:39 PM
Tpx
Tpx's Avatar
Car: 1982+1988 Z28 Camaros
Engine: 1982=350 carb 1988=383 Carb
Transmission: 1982=4 speed T-10 1988=6 speed T56
Axle/Gears: 1982=stock
I have a freshly rebuilt 350 sbc with hei, qjet and no computer. Blue smoke is coming out the tailpipes at 2500 rpm and above. My first thoughts were running too rich, but it was tuned correctly before it was rebuilt and this wasn't happening. Now that the engine has been taken out rebuilt and put back in this is happening. What could be the cause?
Was driving it home from the shop that just put it in when I noticed this. Shop said it was just cause it was running very rich due to the computer controlled qjet not having any computer to manage it. How can I adjust this?
Old 03-20-2009, 01:50 PM
383roller's Avatar
Car: '86 Iroc-z
Engine: 385 stroker, vortecs, demon 750
Transmission: G-Force T-5
Axle/Gears: 9-bolt, 3.27s
Re: Blue smoke out the tailpipes - newly rebuilt 355
holley or demon
Old 03-20-2009, 01:52 PM
Tpx
Tpx's Avatar
Originally Posted by 383roller
holley or demon
In my post I said it was a qjet, stock qjet if my memory serves. 1982
Old 03-20-2009, 02:07 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Blue smoke is oil being burnt. It is possible it's running so rich that it's diluting the oil and allowing it past the rings.
But, if you have a computer controlled q-jet, there's only one way to adjust it - with a computer.
If you took the computer out, shame on you. You just disabled the best street performance carb system available. I would normally call such an action "stupid", but if it was you, I don't mean to insult; so shall we just leave it at "ill advised"? It also happens to be illegal (doubly so in California).
Put the computer back in, get it operating correctly with all the wiring, sensors, etc. If you don't have those things anymore, it just so happens I have a complete intact '82 system waiting to rescue someone who ill advisedly removed theirs, threw it away, and now needs it again. It was taken out of the car that is receiving a 2000 LS1/T56, which has its own computer system, in case you're wondering why it was removed.
Old 03-20-2009, 06:27 PM
Tpx
Tpx's Avatar
Well I took it by a shop today for a second opinion and they said it was oil getting past the rockers? Something about a bad seal, is that likely?
This situation is bad because I need to get back up to college and the guy who built the engine (and who would fix it free thanks to warranty) is out of town for a while.
I have since ruled out too much fuel, because we hooked an a/f gauge up and it reads slightly rich but nothing drastic that cause such emissions.
About the computer, When I bought the car it had had the computer taken out, and the old qjet put back on (I believe it's because he had a very expensive carb on it and put the qjet back on to keep his carb). So that's not my fault, and I'm not sure I want a computer back in.
Old 03-20-2009, 06:44 PM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
if you don't wanna put the stock computer back in, then you really need an older non-cc qjet, a holley, or a edelbrock carb. you know something not for use computer controlled applications. older qjet might be best if you still have the stock intake. and just remember this when people start ragging you about no computer, cars ran without them for about 70 years or so, not really a need for them. the old school way just takes more work to get to work right, and you sacrifice a little bit of gas mileage, but the mileage sacrifice is probably negligible. do what you want and have fun with it.
Old 03-20-2009, 08:08 PM
Bowtiebruiser's Avatar
Car: 1982 Camaro Z-28
Engine: 350 4bbl
Transmission: Borg Warner Super T-10
Axle/Gears: Richmond 10 bolt 4:10 Posi
I'd say Valve guides, were the heads rebuilt or was it just the bottom end?
Old 03-20-2009, 08:22 PM
five7kid's Avatar
Engine: LS1/LQ4
Valve stem seals, specifically. Either not installed properly or not installed. Sloppy guides is a possibility.
As to the computer - putting it back in (assuming you still have the computer controlled distributor - oh, never mind, I still have that, too. . .) would be the least expensive, easiest way to go, and it would give you a better system than Holley, Edelbrock, or non-computer q-jet.
At any rate, more details about the engine and what was done to it would be helpful.
Old 03-20-2009, 08:36 PM
kmann101's Avatar
Car: 1984 Pontiac Trans Am
Axle/Gears: stock, for now
Yes blue smoke is burnt oil and I have seen countless Chevy engines "burp" blue smoke because of the valve guides and seals. I have seen no harm in this other than it can **** you off because it does it. If the heads have been rebuilt I'm not sure what to say other than deal with it. But if they have not been completly rebuilt I would highly recommend it.
Old 03-20-2009, 08:37 PM
Engine: 350 4bbl
Hey now my 82 doesnt have any of the computer stuff left, MSD distributor, old school big block Holley spreadbore
Old 03-20-2009, 09:47 PM
Tpx
Tpx's Avatar
Heads were rebuilt, AFR eliminators.
This isn't some occasional burp of blue smoke, it's a HUGE billowing thing at 2500 rpm or above. So bad that at 3000 rpm on the freeway I could barely see out the rear view mirror. It's serious, I think. But like I said, engine runs very strong, no hesitation or bogging like to much fuel might do.
I will be buying a new carb that's boost referenced in preparation for a weiand 177, but for now the engine was running FINE before with this qjet computer or not. But thank you for the opinion, I appreciate superior knowledge when it's given honestly.
I will be taking it back to the builder for him to fix all this, but I would like to know what went so horribly wrong?
Another symptom arose later this evening. Engine's running very rough all a sudden, with LOUD knocking sound in unison with rpm's. Higher rpms = louder sound. This knocking's so loud that I hear the knocking CLEARLY over the 4" exhaust with 40 series 4" in 4" out flowmaster dumping behing rear bumper. Isn't that serious?
Oil pressure is above 30 always, water temp always nominal, my engine just seems to want to rip itself apart! I've never had such trouble with an egine, let alone a rebuilt engine. Everything was done to it, ending up costing $1,500 for the block work, head work, new bearings lifters, cam, oil pump, etc. Should be running like a champ don't you think?
Old 03-20-2009, 09:49 PM
Tpx
Tpx's Avatar
Yes they were rebuilt.
Old 03-20-2009, 09:57 PM
Tpx
Tpx's Avatar
Thank you for your input. I'm not sure if it's actually a computer controlled carb, I've been told it is but my car was an indy 500 special edition, it had a 400hp engine in it from the dealer and I'm not sure it was computer controlled.. I've come to find that many of my "stock" parts were special for the pace car edition and not stock for z28's only
Old 03-20-2009, 10:17 PM
Camaro383ci's Avatar
Car: 84 Berlinetta
Engine: Bottle Fed 383ci
Transmission: Stage2 T56 Ram powergrip HD clutch
Axle/Gears: Ford 9" Detroit tru track 4.11 gear
Go drive your car somewhere its safe and no traffic staying at 2500-3000 rpm and then shift to nuetral while simultaneously shutting the car off being very careful not to turn the key all the way off causing the steering wheel to lock. When you come to a stop take a spark plug out and see if its fuel fouled or covered in oil. You may have to take out more than one. At least that would help determine which cylinders are messing up and if its fuel or oil.
Old 03-21-2009, 12:40 PM
383roller's Avatar
Car: '86 Iroc-z
Stop driving it immediately, how many miles has it been since the rebuild? i would definately take it back to the builder. If it is knocking that bad you have a very serious problem your bearings sound like they are already shot. If it was mine i would drain the oil, cut the oil filter and see if there is bearing material inside of the paper.
Old 03-21-2009, 02:30 PM
five7kid's Avatar
Engine: LS1/LQ4
I'm not sure if it's actually a computer controlled carb, I've been told it is but my car was an indy 500 special edition, it had a 400hp engine in it from the dealer and I'm not sure it was computer controlled...
That's easy enough to tell by looking at it. Take the air cleaner off, post a couple of pictures of the carb from front and side.
Old 03-26-2009, 07:31 PM
liquidice's Avatar
Car: 84 Z28 L69
Engine: 305 H.O
Axle/Gears: factory 10 bolt 3:73 posi
also if your car i smoking so much it could be over-honed cylinders,improperly installed piston rings. or the machineing was bad. did he hone with a torque plate? if not the cylinders could be out of round or oblong. but highly unlikely. alo if you have a knocking sound your probably f'ed get it warrentied. ive machined engines in a depot center for the army. if you have any questions just ask, and good luck.
Old 03-27-2009, 10:19 PM
Tpx
Tpx's Avatar
Well for those interested in what was at the root of the problem, it was poorly torqued rockers. Bolts loosened up after a few miles of driving, allowing too much rod play, which caused all the symptoms described here.
When it was taken apart, the rod on #3 was badly bent, and many bolts were working loose. All tightened up and good to go now. No other parts were affected, since the engine wasn't driven much more than 30-40 miles since the rebuild. Thankfully it was fixed before anything else broke. Free fix from the shop, plus a 100 refund on the cost of the work done as an apology. Not much but it's a nice gesture.
Thanks for your help in the replies, unfortunately it wasn't something any of us thought of. Until next time.
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
Hotrodboba400
12-10-2019 07:07 PM
Linson
09-21-2015 01:08 PM
Accerrito22
09-05-2015 09:34 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: Blue smoke out the tailpipes - newly rebuilt 355
