Victor Jr. Intake
Old 02-22-2012, 08:31 PM
Matt61609's Avatar
Victor Jr. Intake
Hey whats up guys. I just got a 84 z28 and i got a question about the intake Im considering using. The motor in it is trashed, i got a 4-bolt main 350 and I found a GREAT deal on a Victor Jr. i just wanted to ask a some questions about it. Im planning on keeping it fairly stock for now. Will this intake be good for street use? I got a 650 edelbrock, should that be good or go 700? i wont be ******* on the motor just get on it here and there. Thanks in advance
Old 02-22-2012, 09:28 PM
71nova's Avatar
Car: 1990 Iroc Z
Axle/Gears: 9 bolt
Re: Victor Jr. Intake
I am running a Victor Jr. with a 650 Holley on a .040 over 350 with Trick flow small Chevy Street/Bracket Super 23 Engine KIt . The Victor is designed for racing to make power between 3500 and 8500 rpms. I do drive the car on the street but it really likes to make power between 3000 and 7000 rpms and shifting at 7000 kind of makes a scene on the street. From what I understand you are supposed to match your cam and your intake for maximum performance. Summit racing equipment's tech line 1 330 630 0240 should be able to point you in the right direction. I told them what I wanted to accomplish and they told me what to buy. The end result was better than what I expected.
Old 02-23-2012, 06:24 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Do not buy it. It is not what you want.
If you want a new intake get a performer rpm. You want a dual plane, not a single.
Old 02-23-2012, 04:29 PM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
Transmission: 5-Speed
Axle/Gears: 2.77 posi
Old 02-23-2012, 04:36 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
"Fairly stock engine" and "Victor Jr." do not belong together in the same sentence.
Have you looked at the specs for the Victor Jr.? If not, take a gander here: http://www.summitracing.com/parts/EDL-2975/
Note the powerband - 3500-8000 RPMs. A "fairly stock" 350 will rev to about 5000 RPMs. That would give you an effective powerband of 1500 RPMs, with a "dead spot" from idle to 3500 RPMs - not a street-friendly configuration.
I also can't imagine putting an Edelbrock carb on a Victor Jr. intake, but in general I seem to have more qualms about using Edelbrock carbs than the average bear.
Old 02-24-2012, 03:14 AM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Agreed x 2
Old 02-24-2012, 11:20 PM
FARTSMELLER's Avatar
need , cam , 3.73-4.10 gears , higher compression ratio , 2800-3200 stall converter to make that intake work right and at that point the 650 carb will be useless or at least a top end limiter not trying to **** on your parade but less is more some times plenty of 450+hp sbc running dual planes
Old 02-26-2012, 02:33 AM
383 Power's Avatar
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
Yes, I learned this the hard way. If you're looking for something that will have low end torque, that is NOT the way to go. I put a similar intake on an 86 Chevy full size. I could drive it on the street just fine with a 2400 stall, but my Cam was a Single profile .218@.050. I had craploads of top end, but no get up and go.
Old 02-26-2012, 07:07 PM
Matt61609's Avatar
Alright thanks guys for saving me on that one. One of my dads buddy's hooked me up with some performance parts being a edelbrock performer intake, brand new heads, comp cam, comp cam lifters, roller rocker arms, and moroso valve covers. All have roughly 50 miles on them or a tank and half of gas on em(most of it was idling) for $350 motor build is in progress
Old 02-27-2012, 12:05 AM
five7kid's Avatar
Engine: LS1/LQ4
What heads? Need specifics. If he told you "2.02 heads", that is about as bad the news could be that I can imagine. Get the casting #'s off of them and let us know what they are.
And the cam. Need specifics. The cam equivalent to "2.02 heads" is "3/4" or "race cam". "RV cam" is also in the running.
Old 02-27-2012, 01:36 AM
Matt61609's Avatar
280 dur .480 lift comp cam he said the heads was of a 80s GM truck ill get casting numbers tomorrow I been busy ripping my z apart.
Old 02-27-2012, 02:15 PM
five7kid's Avatar
Engine: LS1/LQ4
Originally Posted by Matt61609
he said the heads was of a 80s GM truck ill get casting numbers tomorrow ...
I'll wait for the actual casting #'s, but my initial reaction is he should pay you to take them off of his hands.
Old 02-27-2012, 02:45 PM
3rdgenmaro's Avatar
Car: 88 IROC
Oh come on now, they are atleast worth $.10/lb in scrap.
Old 02-27-2012, 03:00 PM
Matt61609's Avatar
The casting number on the head is 462624.
Old 02-27-2012, 03:28 PM
3rdgenmaro's Avatar
Car: 88 IROC
From what I found: 462624 350 76-87 1.94/1.50 2.02/1.60 76cc Crack prone
Basically these heads are good if you are rebuilding your high mileage truck motor and the heads were already refreshened.
But for any kind of build where you want to upgrade what you have, these are not the heads you want.
Old 02-27-2012, 03:43 PM
Matt61609's Avatar
Yeh i read that too, but they're been rebuilt. the been decked, new valves, new springs, new retainers.
Old 02-27-2012, 03:51 PM
Matt61609's Avatar
Previous owner's mess up
Old 02-27-2012, 05:17 PM
lowridetractor's Avatar
Car: 89 Iroc-Z
Engine: 350/carb
Transmission: th350
i dont think that is a good place for a crankcase vent!
Old 02-27-2012, 06:51 PM
3rdgenmaro's Avatar
Car: 88 IROC
Like I said, if you was rebuilding an old truck, and your heads needed all of the above, then yes, that would be a good deal.
Those heads are very low performance and are prone to crack.
What is wrong with the heads you have? If they are completely ruined, or if if they will take a lot of money to get them runable, then those 624s would be fine on a stock rebuild if you were going very low budget.
That cam and those heads are not going to work good together.
Old 02-27-2012, 06:58 PM
five7kid's Avatar
Engine: LS1/LQ4
Yep, he should have paid you to take them off his hands. Those are poor-flowing, large chamber early smog era heads.
$50 for the intake, $50 for the cam/lifters, $75 for the rockers, minus the disposal cost for the heads. I wouldn't give him more than $150 for what he's offering.
Old 02-27-2012, 07:43 PM
Matt61609's Avatar
Everything is BRAND NEW. Well worth more than 150$. The rocker alone from jegs is $180 cam and lifters were $180.
Old 02-28-2012, 06:36 AM
3rdgenmaro's Avatar
Car: 88 IROC
Installed and ran is not "Brand New". Especially on a flat tappet cam.
If you are flat broke, then sell the cam, get a stock replacement, put those heads on, get the engine running, and expect nothing but a 180hp stock motor.
If you want more, then you need to use different heads.
Old 02-28-2012, 09:35 AM
five7kid's Avatar
Engine: LS1/LQ4
But he's foisting off crap heads on you. For that, he needs to give you deep discounts on the other stuff (which you said was used - if it's been run, it's used).
Old 02-28-2012, 05:37 PM
71nova's Avatar
Car: 1990 Iroc Z
Axle/Gears: 9 bolt
Sounds like we're getting further and further away from that Victor Junior.
customblackbird
10-01-2015 04:30 PM
85 Jimmy
09-30-2015 07:56 AM
jerflash
09-24-2015 03:11 PM
toronto formula
09-10-2015 07:31 AM
e3pres
09-09-2015 01:51 PM
Quick Reply: Victor Jr. Intake
