Convertible body reinforcement?
I know most third gen verts. were not factory (so to speak) and done by a third party after the fact. Which in my mind means they all started out as coupes first. What reinforcement or bracing was done to the bodies to make them stiffer when cutting the top off?
Reason I'm asking is because I'm thinking about custom making a full targa from my T-top car and wonder if sub-frame connectors would do the job or if more involved strengthening would be necessary.
Engine: 4++,350 & 305 CIs
Re: Convertible body reinforcement?
ASC cars were TTop cars. There are a few extra braces and things welded or riveted on them.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
If you want to convert a car to convertible, the best thing to do would be to find a convertible in the junkyard and take the pieces and parts off of it.
I would think a really good set of SFC's would probably do the trick (Weld-in). That was the main part of the convertible conversion. They also added a vertical reinforcement in the door jamb area behind the back seat trim. You would not need that part because you would keep the top...
Of course you could get the reinforcements from the convertible AND get the SFC's to tie it all together.
I have a BLK 91 ASC convt TA rust free complete body.
$1000.
Top has no convt top material, I removed it and the headliner to see how it was put on and if I could re install it on another frame, which I did.
Hey OK...whatever happened to Bill Speed I still have his 89 Formula 350 convt?
$1000.
I chatted with Bill about 6 months to a year ago. We kind of met on ebay and chatted back and forth about a computer. I do not think he will be back any time soon as he no longer has a 3rd gen...
John
John
I was sooo tempted to buy the car when he had it for sale... Unfortunately I think it was so far gone that it would have ended up as a parts car
With the exception of 4 IROC 350's in 1987, only 1989 was there a 350 even available as a convertible, and that was Firebird only.
Ultimately there was 143 GTA/Trans Am 350 verts and 42 or 43 Formula 350 verts.
The only reason I considered parting it out was because it was so far gone. Every panel on the car seemed to be really rusty, and it would be less expensive to just find one done than to restore it.
Any 350 ASC convertible is rare, Less than 200 were made in total for the entire 3rd generation...
John
John
The car isnt that bad. I have a mint hood $100
Doors $150 each
fenders $50 each
Trunk lid $75
Front bumper crack repair $100
New top $250
Then all that's left are quarters which I admit aren't the easiest thing to do but its such a rare car I can't see parting it. I did the trans
If I give you last 6 of VIN can you give me a run down on car and what # build it was?
Doors $150 each
fenders $50 each
Trunk lid $75
New top $250
1992 Trans Am
05-10-2023 07:19 PM
