Is this a good replacement radiator?
Car: 1982 Camaro Berlinetta
Engine: GM crate motor Goodwrench 5.7 350
http://www.ebay.com/itm/3-ROW-ALUMIN...FUW9c8&vxp=mtr
The specs look like it would fit, I know some people have issues with a 3 row vs 2 row, and unless these fans magically work better than a stock electric I will dump them.
Re: Is this a good replacement radiator?
Speed Daddy?
There might be something of interest here:
https://www.google.com/search?q=Spee...adiator+review
1 Post
Car: 1988 Gta trans am project 1-1/2
Engine: 86 4 bolt main cammed sbc 355 hsr
Transmission: 89 wc bw t5
Axle/Gears: Bw 9 bolt (3.27) pbr 11in
yea its called look at the sticky in at the top of the page they have a good 3 row radiator that is a direct bolt in, into these cars just have to trim the rubber mounts on the top and bottom to make it fit with the top radiator bracket
1 Post
for fans look into the stock 87-92 gta/iroc dual fans or you could use 93-97 lt1 fans or ls1 fans as well since these are kind of a direct bolt in as well
You realize the Champion one in the sticky is twice the price right?
MarkF
05-28-2016 09:45 AM
