84 camaro heating problem
Old Jul 27, 2016 | 05:52 PM
Jonyb84z28's Avatar
My car runs at about 230 without running the a/c and about 240 with a/c. on high way it runs about 225. My radiator fan runs all the time. Are these temps good are bad? Is the fan running all times good or bad?
Old Jul 27, 2016 | 06:58 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: 84 camaro heating problem
Normal operating temps................
Old Jul 27, 2016 | 09:01 PM
Jonyb84z28's Avatar
So that's normal temps? When driving with a/c it's right under the red lines
Old Jul 28, 2016 | 12:16 AM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Is your air dam in place and intact? Look under the front of the car. It's the black plastic thing sticking down going all the way across under the radiator
And what are the temps where you are located ?
Old Jul 28, 2016 | 08:31 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Jony.....
What engine do you have? Electric or mechanical fan?
Elec. fans will run anytime if the A/C is on.
IIRC elec. fans will turn on at 238 degrees.
Old Jul 30, 2016 | 06:07 PM
Jonyb84z28's Avatar
Yes it is intact. I live in Phoenix when highs get about 115
Old Jul 30, 2016 | 06:09 PM
Jonyb84z28's Avatar
Jony.....
It's was the original 305 5.0 ho but now it's a 350 but even when I had the 305 it would do the same. It's an electric fan that runs all the time
Old Jul 30, 2016 | 06:50 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I know the feeling, I'm in Bakersfield and it's 110 out there right now. These are pretty normalish temps for the conditions we have to deal with. Do you have a 180 degree thermostat in there? It will only keep it from heating up quite as fast and then make no difference, but it could help a little on short drives. There's also water wetter and a couple of coolant additives that make a little difference for me. You always have the dual fan option as well but in a month or two it will go away and get more normal...
JamesC
Aug 5, 2016 07:41 AM
RANwithSCISSORS
Apr 23, 2016 08:01 AM
ndndndnd
Apr 19, 2016 10:28 AM
jjjosh
Apr 7, 2016 10:38 AM
backtothe80s
Mar 29, 2016 01:02 PM
