Car Will Not Go Into Diagnostic Mode
1 Post
Car: 1992 Camaro (Z28 Clone)
Engine: LB9|TPI
When I jumper the pins to put it into diagnostic mode nothing happens.
Anyone have an idea what this could be, is there a fuse that powers it.
BTW the car is a 1992 Camaro RS that I swapped an LB9 into, its speed density TPI
Any help would be appreciated.
Thanks!
Thanks!
1 Post
Engine: LB9|TPI
Re: Car Will Not Go Into Diagnostic Mode
Yes the SES light comes on when I first turn the key. Engine is off.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Did you move the wire from "E" over to "M" on the ALDL ?
It connects with the tan airbag wire on "M".
1 Post
Engine: LB9|TPI
Dyno don,
I did not move anything on the ALDL. Do you now what color the wires that should be going to the A&B terminal should be?
1 Post
Engine: LB9|TPI
I purchased a new ECM and that did not solve the problem.
I also tested the ALDL connector with a test light and A had power. Is this normal?
Car: check
Engine: check
Transmission: check
Blink is good, flashing is bad. The blink means that the ECM is running from the PROM, and not in limp mode.
RBob.
RBob.
Linson
08-21-2015 02:12 PM
db057
08-11-2015 10:11 PM
