AUJM -> APYP for t56 swap notes, open for examination
Old 05-01-2013, 03:54 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Hi everyone,
been working on my tuning a bit for my t56 swap. Car is a bone stock 89 350TPI 700r4 3.27 car using AUJM. I have gone through one by one and looked at every single difference between the AUJM and the APYP using $6E & TunerPro. Below are my results.
I have questions on the parameters under ***Different but not changed:
I have also posted what I have copied from the AUJM to the APYP bin.
Wondering if a couple people might give it a once over to see if I have made some obvious mistake or if information can be shared on the "Different but not changed" categories. This is my first stab at tuning so bear with me.
Thanks in advance
Scalers::
***Changed: AUJM --> APYP
Fuel Cutoff Engine Speed (6000)
Fuel Resume Engine Speed (5800)
Min Coolant Temp for Highway Mode Fuel
Min Speed for Highway Mode Fuel
Idle Speed Adder A/C On
Shift Light Enable Vehicle Speed Thresh.
Shift Light Force On RPM Threshold (enable & Disable)
BLM - Update Rate
Display Injector Flow Rate
Minimum Delta LV8 For Accel. Enrich.
Falgs::
Normally Open Fan Request Input
C.A.R.S. ??
Tables::
Main Spark Advance Vs. RPM Vs. Load
Spark Advance In Power Enrich. Vs. RPM
Maximum Knock Retard Vs RPM In P.E.
P. E. %ChangeTo Fuel/Air Ratio Vs Coolant Temp.
P. E. %Change To Fuel/Air Ratio Vs RPM
%TPS To Enable Power Enrich. Vs RPM (Normal)
Open Loop Fuel/Air Ratio %Change Vs. Coolant Temp.
Open Loop Fuel/Air Ratio %Change Vs.Load
Startup Fuel/Air Ratio %Change Vs. Coolant Temp.
Startup Enrich Decay Amount Vs. Startup Cool Temp.
Startup Enrich Decay Delay Vs. Startup Cool Temp
Fan Control Coolant Temperatures (on=100 off=92)
Start Up Spark Advance Vs. Coolant Temp.
Cool Compensation Spark Vs. Load Vs. Cool. Temp (very different)
Injector Pulse Width Correction vs Battery Voltage
Maximum Knock Retard Vs Load, (Not In P. E.)
Highway Mode Spark Advance Vs. Load
Highway Mode AFR Vs. Load
Fast O2 Rich/Lean Threshold Vs. MAF
Old 05-01-2013, 04:19 PM
MrWillys's Avatar
Re: AUJM -> APYP for t56 swap notes, open for examination
I think you should consider using the ANYX spark tables. Not enough timing at idle for the manual in the AUJM.
Old 05-01-2013, 04:24 PM
Keoman's Avatar
Just out of curiosity, why would the timing need changed between auto & manual transmissions?
Old 05-01-2013, 04:31 PM
MrWillys's Avatar
The biggest differences I've noticed between manual and automatic is the spark map. Whether Corvette, or iron headed L98's. You shouldn't use the Corvette, because it has too much total timing due to aluminum.
Old 05-01-2013, 04:32 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Manual doesnt have a torque converter or trans pump to run. Less load it can tolerate more advance i guess.
Shouldnt matter the apyp is a manual bin for the same motor basically, except may have L98 vette timing which is very aggressive for iron heads
Old 05-01-2013, 04:39 PM
MrWillys's Avatar
He's using the aujm spark tables.
Old 05-01-2013, 04:57 PM
Keoman's Avatar
I see. I did notice in the graphs that the APYP is crazy aggressive. Thats why I ended up switching to the AUJM
How would I go about seeing how far up I can push the spark advance?
Oh and what is CARS??
Old 05-01-2013, 05:09 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Timing you just set and run. Log car and see if it picks up knock retard. If not try another deg or 2 til it does experience timing retard. Then back off 2. Thats generally a method to try
Old 05-01-2013, 05:36 PM
Keoman's Avatar
Sounds good. I'll have to figure out how to log and read the info a little later on. Probably not that complicated.
These are the tables I'm most worried about not changing from AUJM to APYP:
Anyone have any advice?
Old 05-01-2013, 07:01 PM
MrWillys's Avatar
The highway mode spark, and fuel in the APYP BCC is not enabled. Look in the constants for highway mode temp enable, and fuel and it should be set at 151.25 Celsius. IMHO, the other table won't make a big difference, but you could always try?
Old 05-01-2013, 11:52 PM
Keoman's Avatar
Perfect, I'll check it out. Thanks
oh and CARS is old jargon for CAGS, case anyone was wondering (me)
more commonly known as Computer Activated GaynesS
Old 05-30-2013, 06:00 PM
Keoman's Avatar
Well, got my memcal modified with a ZIF and burned my t56 APYP chip and it works great.
I noticed while using the old BCC, the car was prone to stalling when the clutch was depressed while decelerating or at low RPM's in traffic. It was an inconvenience at first until it almost caused and accident.
I would be more than happy to share this .bin for safety's sake.
On another note, I put in a 170* thermostat and changed the fan to come on at 212*
Trying to decide what a good fan switch would be for the pass head? Idea's?
Oh, meant to ask. Do you mean to bump the entire table up a degree or two at a time or pick a range?
Old 06-02-2013, 10:04 AM
EagleMark's Avatar
What was the reason to not start with APYP? Copy in what you think you need from your bin.
Even if you changed every single parameter exactly, you would still be missing a lot because not all parameters are defined as a changeable item in software.
Example IAC throttle follower would be there, filter coefficient is not. So will it work right?
Manual to Auto bins have huge differences, IAC logic, Dfco, Decel, etc...
Old 06-03-2013, 12:08 AM
Keoman's Avatar
Looking at the thread title again I can sort of see where you would think I had copied APYP data into the AUJM bcc, but this is not the case.
APYP was used initially, AUJM data was copied from.
BlackphantomZ28
LSX and LTX Parts
10-19-2015 06:25 PM
jharrison5
08-19-2015 05:53 PM
sreZ28
08-14-2015 07:48 PM
1992 Trans Am
08-08-2015 08:16 PM
Quick Reply: AUJM -> APYP for t56 swap notes, open for examination
