newbie at proms.... burning ect.
Car: 85 iroc tpi t-top
Engine: 383 tpi
Transmission: built 700r4
Axle/Gears: 4.56
Hi.
Im building my 85 iroc tpi to a 383 cammed an running 36# injectors I have aluminium l98 heads,1.5 roller rockers. Holly stealth ram intake 58mm throttle body. Needing some insight on how to tune, an what I should be looking into buying to start burning tunes
Car: 90 camaro rs
Engine: 5.7 tpi
Transmission: t-5
Axle/Gears: 373
Re: newbie at proms.... burning ect.
good luck . im looking for same thing. building 90 Camaro. found 5.7 tpi on craigslist with t-5 1500$ right down the street and couldn't pass it up cleanest motor i ever seen . car was gutted for carb . as i was going to drop my carb 350 until i found this tpi.now im running into ecm decisions. 90 rs was 305 with t5 nice but i have nothing to go by . just building from scratch. just got done putting column in . this is my first f body build and its a fight.
Engine: 383 tpi
Axle/Gears: 4.56
This is my 2nd f body build bit my first tpi build.
Car: check
Engine: check
Transmission: check
It is a 4K BIN using the 2732 EPROM, which is not worth using. Most folks get a G2 adapter and the 27SF512 PROMs, then the Burn1 to burn the PROMs. Could also go with an Ostrich and the booster board if you want to emulate.
While at moates.net look at getting an ALDL cable to data log.
RBob.
Car: check
Engine: check
Transmission: check
Yours is a different situation then the OP's. His stock ECM runs a TPI set up as that was what the car was equipped with from the factory.
In your case the stock ECM (1228746, 5.0L TBI), won't run a TPI set up. If you want to use a '90 - '92 TPI ECM will need to re-pin the ECM harness connectors for it. There is a sticky on this on the TPI board here.
Note that the '90 - '92 ECM ('7730) is different then the '85 TPI ECM.
RBob.
RBob.
Upgrading to the 86-89 1227165 and using the $6e mask would be a huge upgrade.
You could get a moates.net g1, a few sst27sf512's and a burn2. Or if you decide you want to emulate time and money hands down look into the dynamic efi Ebl p4.
Car: 90 camaro rs
Engine: 5.7 tpi
Transmission: t-5
Axle/Gears: 373
just need to figure out what sensor is supposed to run with this motor 87 5.7 tpi.
body came with map sensor on firewall. and motor didn't come with maf sensor. plus I have no charcoal canister or vacuum lines ran. I don't need emissions here so I just need to plug in what is necessary to get this thing moving.
Car: check
Engine: check
Transmission: check
The EBL system are all speed density, so they require the MAP sensor. No MAF required.
For vacuum lines, need one to the MAP and one to the FPR.
RBob.
RBob.
Car: 90 camaro rs
Engine: 5.7 tpi
Transmission: t-5
Axle/Gears: 373
Need steps on hooking dynamuc flash ebl up . 90 rs with 87 5 7tpi
Looking for pin charts for ecm connector
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
rubblerubble
03-13-2016 06:57 PM
Glowsock
09-11-2015 11:09 PM
