rear body panel switch
Old 07-02-2007, 08:47 PM
oldtimer's Avatar
I am just beginning to dig through this 88 IROC I just bought, and was wondering what the flat contact switch was for on the rear body plastic panel. It has a matching partner on the hatch, and they obviously contact when the hatch is closed. Is this part of the hatch pull down? My upper switch has a broken pin, and I am wondering what it is and whether or not it is still available new, or not. Thanks, Oldtimer.
Old 07-02-2007, 09:04 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: rear body panel switch
The contact plate should have 4 contacts. They are for the high-mount stop light (HMSL) and the optional wiper (if I'm not mistaken - if I am, somebody please correct me).
Hope this helps.
Lou
Old 07-02-2007, 11:24 PM
slackett1's Avatar
Car: 89 TransAm
Engine: 305TPI
You are right. There are 4 contacts. My 89 TA has only 2 in use, for the tail light in the spoiler
Old 07-02-2007, 11:58 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Correct. Early cars used it for the optional rear wiper motor. When the HMSL moved from the top of the hatch to the spoiler it was used for that. Just used two contact pins on the top piece from then on since that is all that is needed to power the HMSL.
Lon
Old 07-03-2007, 02:09 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
yeah apparently theres four contacts but only an X numberof them were actually used on a given car
i found that out on an 88 camaro i stripped that had a third brake light but nothing else back there
weird stuff
or interesting
sort of
i think i still have the contact plates laying around somewhere in the building here, i rmemeber seeing one in the basement earlier this year, but dunno where now
maybe
unless i finally tossed them in scrap
goood luck
Old 07-03-2007, 07:11 AM
oldtimer's Avatar
Thanks, guys. It looks like only 2 of the 4 were used here, too, as the car does not have the rear wiper. One of the two tabs on the hatch is broken off, but I haven't checked to see if the light works or not. I don't recall my 82 having the plate, but it was a non wiper, pre hmsl car. Thanks, Oldtimer.
Old 07-03-2007, 09:38 AM
Overcast32's Avatar
Engine: 305 TPI - LB9
Transmission: 700R
Interesting... I have two contacts - but no center brake light or wiper in the back. I had assumed it was a sensor for the hatch pull down.
I'm curious - did all 1988 T/A's come with a center brake light? I know it was around that time they were optional, I forget when they started to become standard..
Old 07-03-2007, 08:05 PM
oldtimer's Avatar
Overcast32, the hmsl became federally mandated starting in the 86 model year. They resided on the top of the hatch the first year, and moved into the spoiler area after that. Later on, they moved to the inside of the rear glass, but I do not know if wiring was the same through the years. If a post 85 car has no hmsl, it was removed by someone, or a hatch/spoiler was swapped somewhere along the line. Oldtimer.
1992 Trans Am
05-10-2023 07:19 PM
Exxon Limited
Camaros Wanted
22
12-21-2015 10:36 PM
BlackBoulder
08-11-2015 11:15 PM
Exxon Limited
08-09-2015 08:13 PM
z28addict8490
08-07-2015 08:48 PM
Quick Reply: rear body panel switch
