Need help with wiring "Seatbelt" light...
Old 02-22-2008, 03:19 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Recently I've had some issues with my seatbelt light coming on at random. Searching through the threads I figured out it was an issue with the blue box in the (in)convenience center. But also while reading through threads, I read someone used the fasten seatbelt light as a nitrous armed indicator... Which I think would be a killer idea, specially for a hidden system. Does anyone know if there is a way to control the light aside from removing the blue box in the conv center? There has to be a wire in the red circle (below) that regulates its 12v or ground? Also, can the rest of the "indicator spots" on the dash can be utilized (red arrows)?
Thanks in advance...
Attached Thumbnails Need help with wiring "Seatbelt" light...-022108_1547-00-2.jpg   Need help with wiring "Seatbelt" light...-022108_1552-00-1.jpg
Old 02-22-2008, 02:03 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Need help with wiring "Seatbelt" light...
The seatbelt signal comes to the "chime module" through a black wire, to pin E. It's just a simple switched ground (grounded with seatbelt off).
The chime module drives the yellow wire (12V on pin G) to light up the Seat Belt Indicator lamp in the dash.
diagram
Hope this helps.
Lou
Old 02-23-2008, 12:03 AM
HCR13's Avatar
Car: 1987 Trans Am
so does that mean if I cut the yellow wire and apply 12v it will light up? (and ground the black wire?)
Also, I disconnected the black connector on the actual seat belt retractor, should I just constantly ground that, and selectively apply 12v to yellow wire?
Old 02-23-2008, 06:16 AM
HCR13's Avatar
Car: 1987 Trans Am
well, I figured it out. I just cut the yellow wire and gave it 12v and it lights up. Not really sure where the ground is, but the 12v lights it up. I'm going to hook it up to my NOS system tomorrow...//hcr
Old 04-12-2009, 09:15 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
awesome I also need help in this area thanks for the great onfo
Old 04-12-2009, 02:31 PM
HCR13's Avatar
Car: 1987 Trans Am
no prob. It also gets rid of the annoying seatbelt chime...
Old 06-04-2009, 01:34 AM
ughmas's Avatar
Car: '90 Formula '88 GTA
Engine: 305 TPI 350 TPI
Transmission: T5 700R4
Axle/Gears: 3.42 10 Bolt 3.27 9 bolt
my seatbelt light is randomly coming on as well, how would go about fixing it? where is this convenience center located?
Old 06-04-2009, 02:29 AM
HCR13's Avatar
Car: 1987 Trans Am
This is the [in]convenience center... Take the bottom hushpanel off (the big plastic piece above the pedals) and you should see it toward the back of the radio area... if somehow you can't find it, put the key in and open the door so you hear the chime... the big blue plastic thing is what makes the chiming noise... good luck
Old 06-04-2009, 10:24 PM
ughmas's Avatar
thanks for the help, i just cut the yellow wire cause i always have my seatbelt on dont need the light. was a quick fix for the problem
Old 06-04-2009, 10:44 PM
HCR13's Avatar
Car: 1987 Trans Am
no problem
Old 07-12-2011, 12:45 PM
87GTA_Rock's Avatar
Originally Posted by HCR13
no problem
Thanks so much HRC. No one had any idea what I was talking about till I came here. Took 5 min to fix and it was free. Lol
Glowsock
01-09-2017 04:06 PM
Caspar
06-19-2016 11:19 PM
ndndndnd
Carburetors
17
09-05-2015 06:24 PM
Bryan F
08-27-2015 07:28 AM
Bert87
08-23-2015 03:50 PM
Quick Reply: Need help with wiring "Seatbelt" light...
