c130 alternator help
Old 05-04-2008, 03:26 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
are there any quality alternators out there that put out amperage at idle?
i have a cheap parts store replacement, and even a smaller pulley doesnt help it at idle.
i went to a website where it showed the output, and a cs130 case only puts out 45 amps at idle. i run 3 fans, waterpump, and fuel pump. at night with headlights and foglights, its down around 10 volts on the gauge.
just like a lil more down low. i dont want to spin a 140-160amp alternator.
Old 05-04-2008, 10:02 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: c130 alternator help
I have a rebuilt stocker which outputs 140 amps with no problems, even has a slightly smaller pulley to output at idle.
You might spend a bit on one, Excessive Amperage makes alternators that output 200 amps or more, I've heard many good things about them. Don't know offhand how much it takes to spin it though.
http://www.excessiveamperage.com/
Old 05-04-2008, 11:41 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Have you looked at a CS-144 from a 1995 lumina van or the like?
Old 05-06-2008, 05:34 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
thats way more than i need.
my alt is a 100 or a 105, but only puts out 40 at idle.
ive seen some online that are "beefed up" to spin more power at idle.
thats the only place i really need the power. i dont have any issues otherwise.
nio sir, but i will.
thanks!
RS Reaper
10-17-2018 07:52 PM
apie2546
10-16-2016 02:24 PM
SRKLEGIN
10-03-2015 10:11 PM
RS Reaper
09-27-2015 07:04 PM
raymondandretti
09-27-2015 06:43 PM
Quick Reply: c130 alternator help
