What is the plug on the stock alternator?
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I am wondering what that plug is that is on the back of the alternator because I am currently running an old style Gen I motor with a 1-wire alternator but soon I will be running the stock serpentine brackets that will hold my F1 procharger. When that happens I will need to go back to a stock style alternator.
Can I just hook up the battery to the back of the alt. and not worry about that plug? Some modification I can do to do that?
Thanks for any help.
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Re: What is the plug on the stock alternator?
You can go to Summit or Jegs website and find the alt. for the serpentine setup in 1wire configurations . The cost is around $200 from either place .
1 Post
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
The 2 pin plug on it is kinda needed for that application. If im not mistaken one is for the idiot light no big deal but the other is a voltage reference for the alternator and is kinda important. So you will need to wire atleast that wire back in or go with a one wire set up.
Engine: LS3
Ah... Interesting. As long as 1-wire setups exist then I am all set. Shame that I can't use me alt that I already got.
I may look into somehow converting it, but it might be too much hasstle.
Anyways, Thanks for the help.
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
http://www.austinthirdgen.org/mkport...8_charging.jpg
Its not a dummy light. The big wire gets 12v battery, the smaller 12v IGN
evilstuie
02-28-2016 03:33 PM
eightsixseven
08-14-2015 03:09 PM
db057
08-11-2015 10:11 PM
