Large HEI cap to small dizzy wire harness conversion kit
I got a question guyz. Does anyone have the conversion wiring kit that allows for a small dizzy to be used inplace of the large dizzy? My 86 IROC has the large 4 pin connector (one in the middle) but I want to convert to use a smaller dizzy. So here are the wires and connectors but I cant find a good source to see what exactly is used.....
Exactly what connectors are used to make my own?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Large HEI cap to small dizzy wire harness conversion kit
3rd Gen member S10Wildside has all the connectors cheap on his site.
( not all shown , just ask )
http://www.eficonnection.com/eficonn..._pigtails.aspx
He also has the HEI to small cap conversion harness, just tell him what you are doing
http://www.eficonnection.com/eficonnection/default.aspx
Hey how's it going my friends. I want to build it myself. I figured that I can make one for a total of about $8 compared to around $50. But I'll check into those sites provided and weigh my options. Thanks guys.
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
I just did the same thing, large cap to small cap. I bought the connectors from Summit:
PICO 5602PT & PICO 5615PT
I spliced the 4pin pigtail to the wires from the large 4pin from the factory harness (cut off the large 4pin connector), and wired the 2pin pigtail to a SUM-850500 external coil.
Okay guyz. i checked out the sites and I must say thanks. I really appreciate the help. Now I know what to look for. Agian thanks. But before I go and buy a small cap and remote coil, Would I benefit more from the small cap/remote coil,,, or the 4052 - Hypertech Power Coil large cap and coil?
Go to your local parts store and pick up the other side of that connector. Those weatherpacks are only a couple bucks, you have to buy the pins and green insulators too.
The benefit is that you don't splice wires, it's a nice clean install.
kah992
08-19-2015 02:55 PM
