Brake Warning Light
Car: 74 Nova prostreet 87 Iroc Z28
Engine: 427 671 blower 350 Built
Transmission: 700R4 both
Axle/Gears: Dana 60 an a 323 posi.
Brake Warning Light
HELP The brake warning lite is on when you turn the key on a wont go off I checked the switches an grounded them to see if they would go off an nothing don't know what to do the wire I checked for continuity an it is good I don't want to pull the bulb I even checked the printed cir. on the cluster if you take the sw. out of the pro. valve an check continuity it is good also please help is this light suppose to stay on till the car starts an then go off?
Car: 1987 Black IROC-Z (SOLD)
Re: Brake Warning Light
If the parking brake warning light stay on when the key is turn on---Problems with the braking system, such as a low brake fluid or etc. Not electrical.
I do have fluid an new brakes an bleed the system don't know what to do.
My 84 has a slight leak somewhere...it's not terrible, maybe half a bottle of brake fluid a year, but it's enough to set the sensor off. It beats replacing the system since i can't find an obvious leak anywhere. Not the "best" fix, but I've run this way for 6 years now.
ambainb
04-25-2016 09:21 PM
