Lighting messed up.
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
Lighting messed up.
I have been searching a while now and can't figure my situation out. When my headlights are on, the amber lights (they blink with the blinker on) won't come on. They only work when I use my blinkers. I pull the headlight switch to parking lights, and the only lights that come on are my running tail lights. All the wiring seems to be in tact, I don't see any splits under the dash or anything. Car is an 84 v6 5speed. Any ideas? ?
Engine: 305 5.0L
Re: Lighting messed up.
And the blinker lights stay on with the headlights in park mode, and headlights on. They just aren't on outside the car.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
On Your Marker Lights, Get Set , GO !
Do the Dash Illumination Lights work when you pull the Headlight Switch?
If yes, check the 2-filament bulbs to make sure they are the correct type, and installed correctly.
A common mistake is people installing 2-filament bulbs 180° rotated.
Some crazy symptoms have been reported doing that.
Check all 4 bulbs separately with an ohmmeter or power source to make sure they are good.
Happy Racing !
If Your Engine Blows Up Over The Finish Line It Was Built Perfectly
Happy Racing !
