fuel pump failure HELLLLP
Car: 1990 camaro rs t top 305
Engine: 305 tbi soon to be a carbed 350
Axle/Gears: 2.73 posi
ive got a 1990 rs 305 tbi the fuel pump wouldnt prime now the only way the car stays running is if i feather the throttle and it will run with carb cleaner i bench tested the pump and it had a little pressure maybe 9 psi any ideas
Received 1,672 Likes
Re: fuel pump failure HELLLLP
Sounds kinda low
Try bench testing a NEW pump under the same conditions for comparison
thank you im gonna repalce the pump the sender and filter god only knows what f...tard did it last time i found a cracked and kinked hard line off the filter so its been replaced with a racing filter and high pressure rubber
