FS: L98 long block and 700R4
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Edit: $200 or best offer for all or parts.
The 30 over 350 out of my 87 Camaro are up for sale in the Denver area. Long block includes centerbolt valve covers down to the oil pan, and timing cover to flexplate and everything in between. 1-piece RMS, factory roller cam and lifters, swirl port heads.
Standard and reverse rotation water pumps available..
Last edited by MoJoe; 08-21-2015 at 05:55 PM. Reason: Better details on engine and lowered price
Engine: 4++,350 & 305 CIs
Re: FS: L98 long block and 700R4
Think those are TBI heads. valve covers 87-89?
Car: 87 IROC
Engine: L31 350
Good eye. The car has an "8" VIN, so it originally came with a L98. But the head casting is 14102193, which is the TBI 350 swirl head. DOH! The code pad on the block is smooth, so it's probably been decked, too. Since the block is cracked, I won't be giving anything up by pulling a head to see what other surprises are lurking...
After finding the crack(s), I bought an L31 crate, so I wasn't too worried about what I was pulling out.
Car: 87 IROC
Engine: L31 350
Trans sold.
Revision on engine: 30 over 350 with swirl port heads. Make offer on all or parts.
Car: 1987 Trans Am
Engine: 355 Edel Int, SLP, Edel heders 8PSI
Axle/Gears: 3.45 Borg Warner
Hello, I live in the Denver area as well. I wish i had room for a spare engine but I do not. If you end up parting out the engine, I would be interested in the camshaft for a stock motor i'm retro'ing with a roller setup.
Car: 87 IROC
Engine: L31 350
With the cracked block and TBI heads, I think parting it is going to happen. I'll pull the cam tonight, and get the # to confirm. Do you want the lifters, dogbones and spider too?
Car: 1987 Trans Am
Ok let me know what grind you come up with. I'll let you know if it will work for me.
