zz383 with Stealth Ram Injection
Old 04-07-2008, 05:05 PM
HonkyTonkMan's Avatar
I was wondering how much power can i expect out of a GM Preformance zz383 crate engine with the Stealth Ram injection kit ?
Anyone have a idea ?
the original dyno sheet says 425hp/449ft.lbs with a edelbroch 750 carb!
And off topic, how much power will my stock z28 rear end handle ?
Old 04-07-2008, 06:22 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: zz383 with Stealth Ram Injection
It really depends. I have heard some people have no probs with 400 horse, but most break it at that point. I have a 383 putting out 470 horse and my 9 bolt still works great. I just bought a strange 12 bolt to replace the 9 bolt
Old 04-07-2008, 10:44 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
You should be very close to those numbers. A bigger cam, would be nicer.....
Old 04-08-2008, 12:10 AM
ljnowell's Avatar
In a perfectly set up car 400hp is pushing it for the rear. In most cases though, its not that. Its usually traction that kills the rear. If you cant hook, and spin it will take some more. Ive found the same with the t5s. Last a long time behind a strong engine, until the slicks come out.
Old 04-08-2008, 12:18 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
if that motor will make 425 with a carb, you shouldnt lose any with the HSR. I think i've seen 350-360whp with a HSR on top of a zz383
Old 04-08-2008, 02:08 AM
Talking to some tech guys over there and over here,
everyone says i should be rubbing up against the 500 number with the stealth Ram injection kit that i ordered, with the right map avcourse!
Old 04-08-2008, 09:40 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i dont think that motor has the cam to touch 500. The heads may not be enough either but you can get some serious power out of it as is. I think it needs a better cam tho
Old 04-08-2008, 11:23 AM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
I think the heads are enough for over 500. I think they flow 260 on the intake? Not great for a 210 runner, but good nonetheless. But I dont think you'll see 450 with the cam. Another upside to putting a larger cam in there, is that since you don't want to hook with that rear too well, a larger cam will put more power up top where you can use more of it.
hectre13
Car Audio
26
03-03-2022 05:38 PM
Linson
09-25-2021 07:55 PM
NZKnight
10-15-2015 02:47 PM
mfp189
09-27-2015 09:25 AM
Quick Reply: zz383 with Stealth Ram Injection
