305 to 350 and pass california smog in 1985 camaro z28
Old 03-11-2009, 10:10 PM
mrwebb40's Avatar
Car: 1985 chevy camaro z28
I was thinking about switching from a 305 carb motor to 350 carb motor cause my camaro is putting out black and blue smoke out of the exhuast and i'm wondering if its worth rebuilding the 305or getting a 350 motor instead and will it still pass california smog because the 350 motor was not offered in 1985. also what years should i be looking for when looking for 350 motor.
Old 03-11-2009, 11:43 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
A 350 was offered in '85 full size cars like Caprice. So, it would be legal.
But, you most likely still have a problem with the stuff you'd be putting right back on a rebuilt or replacement engine. Find out why it's running rich. Could be something as simple as the O2 sensor. Is the SES light coming on?
Old 03-28-2010, 07:27 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: 305 to 350 and pass california smog in 1985 camaro z28
it doesn't matter if a 350 wasn't offered on an Fbody in 85, what you would need to do if you do get a 350, is transfer all emissions stuff, computer, exhaust setup, basically everything that is plugged to a connector on the ECM harness from a 350 F-Body... it needs to be setup exactly how it's setup from factory...
Old 03-28-2010, 09:26 PM
five7kid's Avatar
Engine: LS1/LQ4
But, that isn't what he did, so what I said is still true.
Old 03-28-2010, 09:29 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
he hasn't done anything though... has he? He said he's thinking about it... so the only he can put in a 350 is by switching over to TPI...
Old 03-28-2010, 10:21 PM
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
this is some what true...i have a 83 camaro with a 350 with 305 heads that came out of a truck that just passed smog in California...
Old 03-29-2010, 01:41 PM
five7kid's Avatar
Engine: LS1/LQ4
All 3rd gen f-body 350's had TPI. That doesn't mean you have to put TPI on if you swap to a 350 if your chassis isn't newer than the last certified carb'd 350 passenger car.
Old 03-29-2010, 01:50 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
He needs it to pass California Emissions... if he puts in a 350 without TPI, I think he'll end up opening up a can of worms...
Old 03-29-2010, 02:19 PM
five7kid's Avatar
Engine: LS1/LQ4
Actually, putting a 350 TPI in it would kick off the "motor change" can-of-worms process. Whereas putting a carb'd 350 in might not even get noticed.
Technically, both would need to go through the "motor change" process.
Old 03-29-2010, 02:36 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
Yep... it all depends where you take it to get smogged... some places don't have a clue, but other places they have competent people that know what to look for... and yeah you may be right that just doing a swap would probably get him by, he would just need to get it tuned elsewhere on the day of the checkup...
Vintageracer
01-10-2020 05:33 PM
onefreakz
05-14-2018 12:15 PM
84z96L31vortec
08-20-2017 12:16 AM
st.evel07
08-13-2015 06:15 PM
84z96L31vortec
08-10-2015 08:27 PM
Quick Reply: 305 to 350 and pass california smog in 1985 camaro z28
