Help me find a cam for my 383 setup
Old 05-07-2011, 12:26 AM
NathanLewis's Avatar
Car: 85 camaro z28
Engine: 355
Transmission: t-5
I haven't bought anything yet, but I've been planning on running this setup, and I need help finding a cam that gives me good horsepower but doesn't suck up all my gas...
Here's what I've got planned so far...
350 block bored 30 over
Compression 10:1
crank scat steel 3.75 inch
Rods scat 5.7 inch H-beam
Pistons/rings federal mogul forged, 1/16 inch rings
Oil pump Melling standard pump
Oil Pan milodon 5 qt.
rocker arms Roller 1.5:1
Cylinder Heads 220cc runner size, chamber size 72 cc
Valve sizes 2.08/1.60 inch
Intake Edelbrock pro-flo EFI single plane
carburetor 1000 cfm throttlebody 36 lb injectors
ignition MSD-6a
Headers 1 3/4
Any camshaft suggestions? I'm Aiming for 400 hp
Old 05-07-2011, 03:54 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Help me find a cam for my 383 setup
Engine or wheel Hp? Big difference
Why such BIG heads for a low Hp street 383?
Most run 195's
Also current thinking is to have as small as possible chamber (< 64cc ); makes for better combustion and spark propagation
Old 05-07-2011, 09:31 AM
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Most run 195's
Engine horsepower....
I guess I kinda thought those heads would be good, but ill go with 195's...
Old 05-08-2011, 12:38 AM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
What year is the block?
Are the heads aluminum or iron?
Old 05-08-2011, 11:18 PM
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Its a 350 sbc 1996-2000 block from summit racing, already bored out 30. over.
The heads are iron. I don't think putting aluminum heads on an iron block is a good idea. Just my opinion.
Old 05-09-2011, 01:23 AM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
Transmission: Megaraptor
why not??
also, i agree with the 195 and 64 cc quote.
but im biased, thats what im running on my set up. My compression is in the 10.8:1 range though.
im running comp cams 288 xtreme energy cam.
try out their camquest
http://www.camquest.com/
Old 05-09-2011, 09:00 AM
BigJon88's Avatar
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
TrickFlow Heads 195's, 64cc Chamber 2.02/1.6 Valves
1.6 Rockers, Full Roller
Comp Cams XE284H RPM range 2300 to 6500.
240/246 Duration @ .050 .507/510 Lift w/ 110 LSA
this is what i am using the lift is figured with the 1.6 roller rockers
Old 05-12-2011, 10:43 AM
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Originally Posted by CRAMOS78
why not??
[/url]
Because aluminum expands quicker than iron. I'm not saying its a bad idea, as aluminum heads are great, but I just personally wouldn't mix.
Old 05-12-2011, 01:59 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
why not??
Your opinion has been disproven for over 50 years and millions of engines and miles.
Old 05-13-2011, 02:50 PM
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Lol, jerk.
I still don't like the thought of mismatching. /rant.
Nervous2
LSX and LTX Parts
03-10-2016 09:49 PM
gta90
09-15-2015 04:00 PM
LT1Formula
08-20-2015 09:36 PM
86White_T/A305
08-17-2015 12:16 AM
sreZ28
08-14-2015 07:48 PM
Quick Reply: Help me find a cam for my 383 setup
