4" single exhaust with sumped gas tank pics w/in
Old 06-08-2001, 09:09 AM
Guido's Avatar
Car: 2000 Trans Am
Dynomax Ultraflow 4" in/out muffler. The intermediate pipe came from the mufflex system.
-86 IROC
S-Trim, Speed Pro, AFR
this years goal: 10.50 @ 130+ mph
-=ICON Motorsports=-
Old 06-08-2001, 09:42 AM
RW91B4C's Avatar
Awsome, is that thing loud or what???
91 B4C 305 TPI - SOON TO BE 383
TREMEC 5-SP, STOCK 1-BOLT REAREAND w/342 GEARS, K&N, AIRFOIL
EDELBROCK HEADERS, DUAL CAT TO HOMEMADE Y-PIPE & 3.5" SINGLE PIPE W/ FLOWMASTER, CRANK PULLEY, MSD, FUEL PRESS REG, COWL HOOD, WELD WHEELS
14.1@ 98MPH
OTHER RIDE
67 CAMARO - STREET CAR, BIG BLOCK, PUMP GAS
350TH w/ATI 10", 12-BOLT w/373 GEARS
10.94@124.13 ON MOTOR - ET-STREETs w/MUFFLERS
Old 06-08-2001, 10:00 AM
Guido's Avatar
Car: 2000 Trans Am
Dont know yet. I havent got to start it. Im halfway through installing a new Speed Pro ECU and 55# injectors in my car so cant start it right now.
Old 06-10-2001, 12:14 AM
Phil87IROC's Avatar
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
Guido,
Is that the 16" long version of the Dynomax muffler? Let us know how loud it is. I have to get a 4" muffler (or 2) for my carbed 383. I have Hooker LT headers and a mufflex y-pipe (4" out). I was thinking of this muffler or a 16" Borla. I may have to put a 12" muffler then a 16" in series to quiet is down a bit for the street.
What do think?
Thanks!
Phil87IROC
Blue '87 IROC, 383 Crate Motor, KB pistons, AFR 190 heads, ZZ-9 cam, Edelbrock RPM intake, Hooker SC/LT headers, Edelbrock 750 cfm Carb (#1411), stock T-5, GM 3.42 rear w/Auburn posi.
Ohio Valley Dragstrip Trophy Bracket WINNER - 8.39 ET on a 1.82 sec. - 60'. Best MPH = 84.44. Still Tuning Carb!
Red '89 IROC L98, TES, 700R4, T-Tops, K&Ns w/open air boxes, 160 T-stat, Hyper Chip, gutted MAF & CAT, Jacobs Ign., 53kv coil, MSD wires.
[This message has been edited by Phil87IROC (edited June 09, 2001).]
Old 06-10-2001, 10:17 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
That looks mean!!!! Cool as all get out. It'll probably be loud as a fog horn!!!! Especially with no tailpipe. Everyone will know your coming, and when you've passed by. Like to make your presence known, don't you!!! The cops will know ya too.
Old 06-11-2001, 01:05 PM
Guido's Avatar
Car: 2000 Trans Am
I had the dynomax BULLET muffler before with true duals and it was loud as hell. However they had no insulation. There is 1" of insulation all the way around this muffler so I think that it will actually do some muffling. The SLP muffler on my Formula looks like this one looking in the inlet. Corrugated metal with insulation around it. It isnt terribly loud. I hope it isnt MEGA loud. I still want to drive the car once in a while on the street but at this point in its life, its pretty close to a strip car.
-86 IROC
Old 02-09-2016, 09:33 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Re: 4" single exhaust with sumped gas tank pics w/in
-86 IROC
Sorry to bring up an OLD post, but there are no pics on it now!
Guido, can you upload the pic of 4" exhaust and a sumped tank please?
Old 02-10-2016, 12:38 AM
Twin_Turbo's Avatar
Here's a 3.5" system with a sumped tank, could have done 4" but it's tight aeound the panhard support. A little cutting and welding on it can easily remedy that
Old 09-24-2016, 10:10 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
TwinTurbo? What is that muffler?
Brand?
Size?
Old 10-12-2016, 08:11 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
You could also get an aftermarket panhard bar that has clearance for a bigger exhaust.
Old 10-12-2016, 08:41 AM
Twin_Turbo's Avatar
Spintech super pro street 9000 in stainlesd
Old 10-12-2016, 08:43 AM
Twin_Turbo's Avatar
Yes but being on the other side of the world diy and custom built is often the best way. A panhard support is easy to fab
Old 10-12-2016, 08:49 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
I have a founders Panhard bar relocation and it makes for alot more room
Old 10-12-2016, 11:17 AM
midias's Avatar
Oh yea just noticed that. Get the welder out and make it happen
Infested
05-22-2018 11:56 PM
Orr89RocZ
04-25-2016 08:28 AM
Andrew6.688
12-13-2015 10:59 AM
mustangman65_79
09-01-2015 03:51 PM
AkDrifted
08-17-2015 07:45 PM
Quick Reply: 4" single exhaust with sumped gas tank pics w/in
