Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Your Thoughts on This....
Old 09-21-2004, 12:46 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The way this has been drawn up, will this thing work? Basically the idea behind this is to add to the oil capacity of a stock oil pan on a SBC.
Also, if it works the way I think it would, you wouldn't need vented valve covers either, because you could vent the engine and fill it with oil from the tank.
Will this work the way I think it will?
Old 09-21-2004, 12:48 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I think -10 AN or -12 AN would work (don't want stuff crimping up on you)
Other than that, perhaps it would, I dunno.
Old 09-21-2004, 12:57 AM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
and u need more oil why
Old 09-21-2004, 01:02 AM
Air_Adam's Avatar
I don't, but I just wanna know if this would actually work. I'm just really curious.
Old 09-21-2004, 04:25 AM
ede
ede's Avatar
try it and find out. looks like it would and if it didn't it would with a little adjusting.
Old 09-21-2004, 08:19 AM
KAOSRacing's Avatar
In a way, this is almost how dry sump systems work so I'm fairly certain it would work to some extent. It wouldn't be a good as a real dry sump but it should do something.
Also this is similar to the Moroso AccuSump system, except they take pressurized oil from the system and pump it into a 2 or 3 quart container. As long as the pressure remains, the oil stays in the external "sump", when pressure drops off the oil flows out.
If you made your external tank out of aluminum it would also act as a heat sink for any oil that got into the tank.
Old 09-21-2004, 10:00 AM
mykxt202's Avatar
Car: 82 z28
Engine: 400ci 450hp
Why don't you just get a filter relocation kit and use a bigger filter
Old 09-21-2004, 01:16 PM
Air_Adam's Avatar
Could, but not as cool as this
Old 09-21-2004, 11:30 PM
85VortecTA's Avatar
Car: Trans Am
Engine: chevy 350
how are you going to make the sump level to the oil pan? there's no space.
Old 09-22-2004, 12:18 PM
laiky's Avatar
the oil in the secondary tank will never get used. there is no way for it to circulate to the oilpan.
Old 09-22-2004, 09:41 PM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
^^ just what i was thinking
Old 09-23-2004, 09:47 PM
JPrevost's Avatar
Car: 91 Red Sled
:werd:
I found the easiest way to add extra oil capacity is to use the largest filter you can fit. I found the ac delco pf25 was just too small. It's now called a pf452 or something, so go with the pf1218. It is twice the capacity and filter media. Also comes with a decent anti-drain back valve not found in the stock recommended filters.
Another options is an oil cooler with inline remote mount filter adaptor. This is what I plan on doing because highway trips with 3.73 gears (2800rpm) gets the oil pretty hot.
Another idea I have is to replace the drain plug with an line that I can tie up to the bottom of the car. It'll have a plug and to change my oil I'll just reach up under the front fender, unhook the line, let it hang, unplug and drain. Change the filter from under the front bumper cover. That would just make changine oil SO simple. No longer would I need to jack the car up and I'd have reduced my oil temps. I think it could be done for under $100 if I shop around for the parts.
Old 09-23-2004, 10:04 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Originally posted by JPrevost
... Also comes with a decent anti-drain back valve not found in the stock recommended filters...
For the days that you park your car on it's roof.
The other idea doesn't sound half bad, but I'm paranoid and like to inspect everything while I'm doing the oil change.
Elephantismo
02-13-2019 12:51 AM
luvofjah
09-26-2015 08:28 PM
Damon
09-26-2015 04:29 PM
GTAman
09-14-2015 09:53 AM
IROCZ1989
09-04-2015 11:54 AM
Quick Reply: Your Thoughts on This....
