Firebirds for Sale Post your Firebird for Sale.
[PA] '92 305 TBI Firebird plus '93 Camaro donor
Old 07-13-2015, 09:17 PM
scorp88's Avatar
Car: '92 Angrybird
Engine: 305 TBI the "Leaky Bastard"
Transmission: 700R4 with B&M shifter
Axle/Gears: 3.21 Posi off of '93 Camaro(RIP)
'92 305 TBI Firebird for sale. $2000
Hi.
Selling '92 Firebird. It looks like Formula, but has a GTO body kit and no badges that designate it. It's a 305 TBI, so I am not sure what it is exactly. Look at the pictures below. Maybe somebody knows?
This is (was) a sort of father-son project, but now neither of us have time to work on it and I need money to fix the house and free up garage space and have one more kid and wife yelling at me (what a surprise) so it needs to go.
It's not often that I need to sell a car(s) so please bare with me and I'll do my best to describe condition and such.
Let me start with what we've done so far and then I'll describe general condition. You know the good, the bad and the ugly....
-Energy Suspension Poly bushings all the way around
-Fresh shocks
-Fresh steering links
-UMI (I think, it's red) adjustable panhard bar
-Aluminum drive shaft
-LS1 brakes both front and rear with working park brake
-Drilled rotors and new pads (minus about 10K as it sits now)
-LT1 read axle with 3.24 Posi courtesy of that '93 donor camaro
-that thing that goes in with front sway bar and ties up the front. I forgot what it is called, sorry
-Full EGR delete
-AC delete
-55?LB injectors
-Edelbrock air filter
-Fresh generator
-Fresh iridium spark plugs
-Fresh spark plug wires and cap with runner
-Edelbrock headers
-Magnaflow small cat (that didn't pass NJ inspection, but did pass NY because they didn't care as it's pre-OBD2)
-Grant steering wheel
-B@M shifter
-Alpine head unit with all updated Sony speakers. Definitely sounds better than stock
-Good'ish dash pad (not installed)
-New outer window seals (not installed)
-Some other bits and pieces I am forgetting, but that's normal I guess.
Body is in good condition with minor surface rust. There is one "bad rust" spot under AC box thing. This most likely is one of those cars that was painted in California with one of those "eco friendly" paints so it was/is peeling. I sanded and sprayed most trouble areas with spray can primer. The idea was to do a pro paint when we have time and funds so priming job was mainly to prevent further rust.
Car is garaged now, and I haven't seen any more rust spots popping up, at least nothing obvious.
Underside and suspension components were sprayed with Rast Oleum and I thought I did a good job of cleaning prior, but car spend few month in Buffalo and some of it didn't "work as advertised".
Plastic is almost good. There is a small hole in rear bumper and front ground effects are scuffed up and missing small pieces.
Wheels that are on now are the wheels that were on a car. Front ones sporting some major spacer to clear those massive LS1 calipers and as a result rob inner fenders at full turn. But the car was not driven daily and the wheels there mostly "for show" so not a lot of damage in that department.
Interior is as clean as I could get it with few rounds of shampoo and carpet cleaner, but honestly, I'd replace the at least the carpet. When we got the car it smelled rodents and it still does. There is no head liner and no visors.
T-Tops are plastic and for being such are not very smooth on the outside. They didn't leak but start "howling" at around 75 MpH
I installed replacement dashpad and it too cracked. Although it is not nearly as bad as one in pictures.
Engine has circa 74K miles on it, and was ok up until last year when it started leaking from either main bearing or one of the breather holes (I strongly hope it's the hole, but not sure). This was switly attributed to new 3.24 axle which had poor little 305 working overtime.
Asking $2K. Come and get it.
Pictures below.
...with C4 wheels
scorp88's Avatar
Car: '92 Angrybird
Re: '92 305 TBI Firebird plus '93 Camaro donor
Some more pictures
This is how replacement dashpad looked like when I got it. It looks the same now for the most part except one quarter size nick.
..Some poor TransAm donated brake calipers
The filter that's on now is bigger one from Edelbrock. I couldn't find correct picture.
Donor's engine
Donor...
Headers are stainless Edelbrock with EGR tubes removed. I don't know who made Y-pipe.
Old 07-17-2015, 06:02 PM
scorp88's Avatar
Car: '92 Angrybird
Anybody? Somebody please buy it. Excellent winter project. No swap guessing, all there harness, computer, then whole thing!!!
Old 07-28-2015, 07:07 AM
scorp88's Avatar
Car: '92 Angrybird
Last bump before ebay, part out or junk yard
Old 08-01-2015, 08:36 PM
RyanJB's Avatar
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
Would you separate the firebird?
Old 08-05-2015, 08:56 AM
scorp88's Avatar
Car: '92 Angrybird
Yes, I can sell separately. Opened for offers. PM me. Thank you.
Old 08-09-2015, 04:24 PM
scorp88's Avatar
Car: '92 Angrybird
Sunday bump. Still for sale
Old 03-10-2016, 01:03 PM
scorp88's Avatar
Car: '92 Angrybird
Bump again. Can't force myself to eBay, still for sale.
Also would trade for 80 series Land Cruiser flexible on condition as long as it is running and not a complete rust bucket. Light body damage ok.
Old 03-12-2016, 09:55 PM
jmcmillanjr.'s Avatar
Car: 1991 T/A GTA, 1991 T/A
Engine: 350 and 305
Can you post a couple pics of the undercarriage?
Old 03-13-2016, 09:51 AM
TPIVette's Avatar
Car: 1991 Corvette
Engine: 383 TPI
Axle/Gears: D44 3.33 gears
FYI, the Vette wheels are C5 wheels.
Old 03-15-2016, 03:20 PM
goalieforlife's Avatar
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
let me know if u part it..... its a base bird by the look of it. the tbi and spoiler give it away..but there should be codes in the truck storage locker that would give you a better idea of what it was.
Old 03-25-2016, 10:08 AM
scorp88's Avatar
Car: '92 Angrybird
Thank you TPIVette!!
Old 03-25-2016, 10:10 AM
scorp88's Avatar
Car: '92 Angrybird
May as well be base one + ground effects. But considering all the swaps, not very base any more.
I'd part it, but I don't have dedicated space in garage and need it running. And dont' want to move it outside.
Old 08-25-2016, 10:11 PM
Benk73's Avatar
Car: 91 Camaro RS
Engine: 3.1 V6 sadly
Is it still for sale?
Old 09-07-2017, 06:04 AM
scorp88's Avatar
Car: '92 Angrybird
Fall bump. Still for sale. Still flexible.
Old 01-08-2018, 04:41 AM
85irocZ2819's Avatar
Car: '87 z28
Engine: 383
Transmission: t56
Axle/Gears: 10 bolt 4:10
Where you located
Old 09-11-2019, 08:29 PM
scorp88's Avatar
Car: '92 Angrybird
Sorry, hadn't been here a while. Located in Mt. Pocono, PA
Old 09-11-2019, 08:54 PM
Car: '87 z28
Engine: 383
Transmission: t56
Do you still have them
Old 09-12-2019, 10:33 AM
scorp88's Avatar
Car: '92 Angrybird
Yes. Both still here. I wasn't actively looking to sell up until recently. As my kid was kind of on the fence to finish the project. But now he seem to lost interest for good.
We tried to start Camaro last weekend and it looks like starter solenoid went. It still turns over freely and all fluid seem in good shape. Firebird being started and driven at least once a month and kept in the garage the whole time.
So it still as good as it was when I originally posted it. Price is negotiable. Or if you have a running harley road king or any other soft tail we can discuss a trade.... or a Wrangler
Cheers!
Old 09-12-2019, 11:20 AM
Lakerman62's Avatar
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
if the 93 is an A4, I would like to buy trans if you would ship it? As U likely know, the 1993 f body automatics were one year unique 700r4/4L60 with a 5 pin plug....thanks!
Old 09-12-2019, 11:54 AM
scorp88's Avatar
Car: '92 Angrybird
I've heard something about the tranny. Never paid attention to that though. Not sure what the implications are. In any case it is still in the car. I don't have time to take it out unfortunately. Also shipping from PA to Oregon will be $$$$
Old 09-12-2019, 11:56 AM
Lakerman62's Avatar
i understand, thanks for response, best wishes
Old 09-13-2019, 01:42 PM
scorp88's Avatar
Car: '92 Angrybird
Bump with price drop.
Old 09-13-2019, 04:03 PM
CKone's Avatar
Car: 88 T/A, 91 Formula, 94 Firehawk
Engine: 400 Pontiac, 5.0 TPI, 5.7 LT1
Transmission: 700R4, T5, T56
Axle/Gears: 4.10, 3.42, 3.42
Good lord I see a tan drivers side door cup holder in there. If you decided to part with them count me in! Lol.
Old 03-24-2020, 11:39 AM
scorp88's Avatar
Car: '92 Angrybird
Bump! Camaro gone. Now just selling FB.
Old 05-09-2020, 09:02 PM
KR05's Avatar
I PM'ed you. But not sure how that system works. But definitely intrested in the Fb.
Old 08-15-2020, 03:07 PM
KnightAutoPCD's Avatar
Car: 1982 Trans Am & 2000 WS6
Engine: 5.0 CFI & LS1
Transmission: 3 SPD Auto / 6 Spd Manual
Still have the Firebird ?
Motown
10-27-2018 06:00 AM
aarivers
Members Camaros
25
06-11-2014 08:05 PM
91zconvt
09-11-2010 06:37 PM
CYARS92
09-09-2008 01:08 AM
fordsuks91
04-16-2008 03:49 PM
Quick Reply: [PA] '92 305 TBI Firebird plus '93 Camaro donor
