Does my car has WS6 package?
Car: 1992 Firebird Formula 350
Engine: 5.7L V8 L98
I just got it a few weeks ago, and it is a 1992 formula 350. The VIN Number says so and well, how it looks I guess. There's no sticker saying its a formula however.
But anyways, my wheel hubs shows WS6 on them and theres a badge by the passenger side dash that says [Performance Suspension].
Does this mean I have the WS6 package?
Car: 89 Firebird
Engine: 355 TBI
Re: Does my car has WS6 package?
Engine: 5.7L V8 L98
1 Post
Car: 1989 GTA
Engine: LS coming soon
Transmission: 80E coming soon
Axle/Gears: S60/35 Spline/S-Trac/3.73
Post some pictures, I'm curious to see if it's my old 92 formy.
Engine: 5.7L V8 L98
Car: 89 Firebird
Engine: 355 TBI
Nice car man! I really like the 91-92 Formulas. WS6 cars have fast ratio steering box, bigger diameter sway bars, and I think better shocks and springs.
Engine: 5.7L V8 L98
Thanks! It still needs work. Mainly repaint. I applied some body filler on the roof and plastidipped it black just to cover it up. It was all rusty when I got it. No time to totally fix it all up since I'm leaving to BMT on January. Then a transmission swap for a t5 or a t56. Other than that, its perfect. I drive it as a daily and I hope it won't give up on how I drive it here and there.
I saw yours on your profile and it is nice too!
Community Administrator
The VIN itself does not specifically spell out Formula as there is no code in the VIN for a Formula. The Formula and Base Firebird shared the same 1G2FS prefix. Online decoders don't know the difference and you will see them mixed. You need to look for the W66 code to make sure it's a Formula.
Performance Suspension badge does not mean WS6. The badge was included with the upgraded suspension above base suspension, in addition to WS6.
Look for the SPID sticker on the back side of the locking luggage compartment door. Look for W66 (Formula). If it's a Formula, it will also have WS6 as it was standard. All Formulas are WS6.
Engine: 5.7L V8 L98
You can use some reasoning but my point to readers was there is no digit in the VIN that denotes the VIN is a Formula over a Base Firebird. He said his VIN decoded as a Formula, which only GM or Compnine can give that type of answer through actual records. Your typical VIN "decoder" isn't going to be able to tell you as it will tell you Firebird/Formula, just as they "decode" Trans Am/GTA and then people think they have a GTA when they actually may not. And because the Formulas, unfortunately, didn't come standard with the top engines, it's not always that easy. But yeah, if you have your knowledge going in, you can reasonably conclude such.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
The difference between the WS6 and FE1 & F41
- Larger Sway Bars
- Gas filled shocks & Struts
- quick ratio steering box
- Stiffer Springs (IIRC)
It is purely a handling/cornering package from 1987-1992... Prior to 1986 WS6 also included Rear Disc Brakes, 1987 & UP, Rear Disc Brakes were a separate option.
Formulas are the best... Lighter, faster, more nimble, the GTO of the 1980's
- Larger Sway Bars
boardwell
09-04-2017 09:00 AM
aaron7
Interior Parts Wanted
10-08-2015 12:53 PM
natdowson
10-07-2015 12:30 AM
sjorgens
10-01-2015 07:54 PM
