Overhead Console with ABS Headliner
Old 08-12-2015, 05:43 PM
TheJoeY88's Avatar
My original headliner wasn't doing to well after 23 years and over 311,000 miles, so as a quick fix i bought a replacement ABS headliner but it was cut for and came with an overhead console. It was originally installed in a an 86 Trans Am and it fit well and installed easy into my 92 Trans Am with one problem.
There is a pretty large gap between the console and the headliner.
Anyone else run into this? It didn't come with the reinforcement piece, all the special screws are tightened down well. I will say the screws came from another car but i figured all the screws were the same.
Old 08-13-2015, 07:43 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: Overhead Console with ABS Headliner
Abs headliners aren't molded right. You will have to modify the overhead console to get it to fit right. I think I saw the ttop console fits better.
Old 08-13-2015, 09:29 AM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
does the console have the support piece for the hard top version behind it?
this thread has a picture of the support piece needed.
https://www.thirdgen.org/forums/faq-...oth-types.html
Old 08-13-2015, 10:17 AM
TheJoeY88's Avatar
no i dont have the reinforcement piece
Old 08-13-2015, 06:38 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
https://www.thirdgen.org/forums/inte...d-console.html
See items #17 & 18 on the link. I had the same problem when I installed a new abs headliner even after following instructions and using the template to cut the new holes from here on third gen.org. The aforementioned reinforcement piece for the stock headliner wont work on an abs style due to the stronger nature of the material compared to the original style.
Old 08-13-2015, 06:51 PM
TheJoeY88's Avatar
good idea, i will try that, will just try and find some kind of rubber cushions to put in between the headliner and roof
Jorlain
Exterior Parts Wanted
06-29-2017 11:04 PM
Lbibb
05-05-2016 12:00 AM
formula00ra
Interior Parts Wanted
09-28-2015 11:50 AM
ndndndnd
09-28-2015 08:00 AM
MORREALE5
09-13-2015 09:01 PM
Quick Reply: Overhead Console with ABS Headliner
