Strut braces that fit over LS engine
COTM Editor
Received 1,855 Likes
Car: '89 Firebird
Engine: 7.0L
What strut braces are you guys using to clear the LS engine? Preferably a 3 point brace, but I'd like to hear about 2 point brace as well.
Is the answer certain brand names, or is it more about the style (throttle body vs. TPI vs. Carb)?
Fast 102 intake on LS3 heads.
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: Strut braces that fit over LS engine
Eldebrock 3point for tpi works well only issue is if you get camber plates you have to trim abit of the STB mount to get more adjustment room
Car: 92 Z28
Engine: ls3
Transmission: t56
Axle/Gears: 4.11
I have a bmr 2 point for a tpi on mine. Looking at it I think the 3 point version would work, but I cannot verify it.
Pretty much I think any stb for our cars will clear a ls car intake since they sit fairly low in relation to a tpi or carb. Pick a stb you like and run with it.
This is what I plan to do when I FINALLY get my LS swapped in: http://www.hotrod.com/how-to/additio...build-a-brace/
Yes, it will require some fabricating and welding skills.
M
M
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I have Kenny Brown under my car, but they don't make it any more. Too bad because it was, and still is, the best stuff out there!
R3500
08-17-2015 12:16 PM
