Alternator Wiring Issue...1Wire
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
I've searched to no avail.
I have the one wire pigtail connector for my LS Fbody Alt. I need to know where I can connect this into my system to excite the Alt into charging mode. I've heard a 12V switched power works, but just any power? I'm running the Holley HP system in my car.
I really want to drive this since its been 3 years in the making....
COTM Editor
Received 1,855 Likes
Car: '89 Firebird
Engine: 7.0L
Re: Alternator Wiring Issue...1Wire
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Hey, Slush... If you recall, I bought your other Holley HP.
How did you handle speedometer and reverse lockout solenoid?
I ended up using a Dakota Digital SGI-5 for speedo. I have an idea for reverse lockout solenoid to make it behave properly, but not sure if the Holley HP will understand the signal waveform. I would appreciate your feedback.
https://www.thirdgen.org/forums/ltx-...ml#post5821648
Car: 92RS
Transmission: TH350
My speedo is mechanical off my TH350. What is this reverse lockout solenoid you speak of....It probably is a manual trans thing isn't it.
I will go checkout those other posts now. Thanks for giving me somewhere to look.
eightsixseven
08-14-2015 03:09 PM
db057
08-11-2015 10:11 PM
