86 IROC what might i get outta this set up
Car: 86 IROC-Z
Engine: 383 Stroker Vortec
Transmission: 700r4 Built
Axle/Gears: 3:42
I have a 1986 IROC I bought It bone stock almost with a 305TPI headers and a 700r4 273 limit slip rear end, it ran a 15.14 @91mph for best time, scince then I have got the trans rebuilt corvette servos transgo shift kit and 2400 stall the 305 was pulled out and I have a 383 Stroker 10.8 to 1 compression forged pistons rods 906 Vortec heads elgin Cam 484/484 lift RPM air gap intake holley 750 DP carb still has the stock rear end.. wondering what you guys think I will run with the stock rear end and afterwards when I put in a locker and 373s
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Assuming you have traction and a decent tune, you should be in the mid- to high-12s with the 2.73s. With 3.73s and traction, probably low-12s, maybe high-11s. I'd want more stall, though, to insure running those numbers.
Car: 86 IROC-Z
Axle/Gears: 3:42
will thouse work with my rear end scince its 26 now?
Posted from Thirdgen.org App for Android
Car: 1984 camaro z28
Engine: sbc 383
Transmission: Th400
Axle/Gears: Moser 9", 4.11 gear
Re: 86 IROC what might i get outta this set up
You would have to just order a 28 spline locker instead of a 26(if you bought the 28 spline axles). Also, I would think that even with a locker and 3.73 gear my prediction would be around 12.6. I agree with five7kid that with a bigger stall you would be a lot better off.
Engine: LS1/LQ4
Yes, like Greggy said. You can "even" go up from 7-1/2" gears to 7-5/8" gears.
I did all this in my '83 rear, originally with open 2.73 gears and 26 spline axles.
You may want to consider a Detroit Truetrac rather than a run-of-the-mill posi like Eaton. I just discovered broken off posi disk tabs in mine. It'll get a Truetrac next week.
Car: 86 IROC-Z
Axle/Gears: 3:42
I deffinetly wont cheap out on the rear end, no point in spending money on cheap parts
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
My suggestion is to find a 3.23, 3.42, or 3.73 factory 10 bolt for the 3rd gens and swap it in - no reason to spend $1k to break it the same as a factory stock rear IMO.
Car: 86 IROC-Z
Axle/Gears: 3:42
car ran a 13.40 @ 105 un tuned and trans shifting to early Im sure to see 12s after the tunning and issues are worked out
Car: 86 IROC-Z
Axle/Gears: 3:42
13.11 @ 106mph now has Detroit locker 342gears LCA with relocation brackets easy 2.0 lauches other wise it wheel hops
ambainb
04-25-2016 09:21 PM
kah992
08-19-2015 02:55 PM
mustangman65_79
08-11-2015 03:17 PM
