Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
83 Camaro 383 Stroker Oil Pan Stock K-Member
Old 09-23-2014, 09:55 AM
jman_redding's Avatar
Car: 83' Camaro
Engine: 383 Stroker
Transmission: Powerglide
Axle/Gears: 4.56
Anyone now which 7qt oil pan will fit in my 83 Camaro 383 stoker 6" h-beam rods. Car has stock K member. I've searched summit and jegs websites and really couldn't find one that say it is for that application.
Old 09-23-2014, 12:50 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: 83 Camaro 383 Stroker Oil Pan Stock K-Member
we have a 6qt moroso pan on my dads car. any reason you need 7 qts? what else do you need out of an oil pan? windage/scraper? what side dipstick? 1 or 2 pc main seal?
Old 09-23-2014, 04:11 PM
Car: 83' Camaro
Engine: 383 Stroker
Axle/Gears: 4.56
6 qt would work. 2 piece seal 1st gen SBC. Need windage and passenger side dipstick. What model of Moroso pan are you running? Do you have stock K-Member?
Old 09-23-2014, 07:58 PM
mw66nova's Avatar
Engine: 7.0L
i can't find the one we're running. car has a stock k-member still. this one says it'll work with the chassis though, and is 7 qts. you should be able to run a windage tray with this one no problem:
http://www.summitracing.com/parts/mo...t/model/camaro
Old 09-24-2014, 09:46 AM
Car: 83' Camaro
Engine: 383 Stroker
Axle/Gears: 4.56
I was looking at that one too. I will try it thanks for the input
Old 10-02-2014, 03:50 AM
Night rider327's Avatar
Car: 1988 Camaro
I have the summit 7 qt. pan on my 355 in my '88 camaro with stock K member. Fits the chassis just fine, and says will fit up to 3.75" stroke
http://www.summitracing.com/parts/sum-g3502/overview/
Old 10-03-2014, 03:37 PM
Car: 83' Camaro
Engine: 383 Stroker
Axle/Gears: 4.56
Thanks. I found a 7qt moroso that is stroker clearanced. Will see if it fits by the K member.
Old 10-14-2014, 10:11 PM
92WS6 T/A's Avatar
Car: 1992 WS6 T/A
Engine: Turbo 383 with Holley Sniper
Transmission: factory 5 speed now Powerglide
Axle/Gears: Strange 12 bolt w/373 locker
Please update this. I'm in the same boat
Old 10-15-2014, 12:17 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Depth of the pan means very little for a stroker unless you have a huge stroke increase. Increased stroke normally requires a little extra pan clearance along the rails mainly for the rod bolts to clear.
Old 10-15-2014, 09:58 AM
Car: 83' Camaro
Engine: 383 Stroker
Axle/Gears: 4.56
Dropping it in this weekend will let you know
Old 10-24-2014, 09:55 AM
Car: 83' Camaro
Engine: 383 Stroker
Axle/Gears: 4.56
Ok Motors in. I used a Moroso 20191 and it fit perfect. My block is older so the dipstick was on the drivers side but they also make a passenger side version. Plenty of clearance behind the K Member but hangs down about 1/2" below the K member. I was able to stab the motor and tranny in together very happy with it.
Old 11-27-2014, 10:41 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
milodon makes a 7qt oil pan..fits stock 3rd gen cars pass side dip stick.
takes the chevy windg try..fit the SLP headers y pipe set up also..it's bigger the the stock pipe...still have one layn in my old shop with my Lingenfelter 383..just getting dusty.. it needs a new home
mhatfield 14
10-24-2015 07:48 AM
Reddeath210
10-06-2015 08:20 AM
Navy8125
08-21-2015 09:32 AM
MY87LT
08-17-2015 08:43 AM
89mulletbird
Southern California Area
08-10-2015 10:16 AM
Quick Reply: 83 Camaro 383 Stroker Oil Pan Stock K-Member
