RHD TA wiper problem
Hi all,
Only my second post, more of a lurker.
I'm in Australia hence posting here! Purchased an '84 TA project a while back, and it's getting close to being on the road, so close I took it in for a pre roadworthy inspection.
Prior to my purchasing the car it had been converted to right hand drive, however the wind shield wipers are still in the LHD configuration, this is a problem for the powers that be with them indicating there is not enough "sweep" on the new drivers side of the car.
Having just spent $10k on body and paint I'm not to keen to have someone start hacking away at the firewall to remedy the issue. I have been doing some research online and about the only thing I could find that might be useful is a single blade conversion, but as to where I might buy one of these kits I have no idea.
Short version:
Any ideas on how I can increase the sweep of the wind shield wipers to provide more coverage to the right hand side of the windscreen?
Thanks.
John.
Short version:
Thanks.
John.
Car: 85 Firebird C&C T-Top
Engine: 347ci LS1
Transmission: 4L60E LS1
Axle/Gears: BW 9 Bolt Posi,3.27,C5+VE Brakes
Re: RHD TA wiper problem
Thats the main problem with most rhd firebird's in aus, they all still have lhd wipers.
However most are registered with it (been overlooked) as it seems your caught up in the ruling.
I looked briefly at it and even mucked around with some other parts, but with the extremely limited room there wasn't much you could fit.
I'd imagine you'd have to look at maybe european cars for single wiper conversions, or see who the aftermarket suppliers are of the euro cars as a few of them have single wipers.
1 Post
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
The easy solution, at least in Vic, is go for "club" registration which has an easier rwc
Here I think cars need to be 20 years old for classic club rego.
Car: 89 IROCZ vert
Engine: 305TPI
I was doing some car stuff paperwork filing and was reading my engineer conversion and modifications done (QLD ). Mine are still original sweep however to meet the required design rule the wipers were extended by 30mm (via longer wiper blade) and this met the design modification for 97when it was converted.
Glowsock
09-06-2015 06:40 AM
