Third gen 1LE brakes on a 2nd gen?
Old 06-20-2001, 05:47 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Does anyone know if you can retro fit third gen 1LE front brakes onto a 2nd gen (1970) Camaro?
82Z 305 w/comp 270 magnum cam,Edelbrock Performer RPM,Holly 1850-4,serpentine belt drive.TH700R4 w/B&M holeshot 2000 converter,& megashifter.1LE front brakes, 9bolt 3.27 w/1LE rear brakes.Aluminum driveshaft,boxed rear susp.poly everything,IROC swaybar+wonderbar. 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side,but not too bad
Old 06-22-2001, 08:31 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Andy...you can install the old b-car 12" rotors and spindles from the mid 70s (77-79 I think)wagons others im sure. I had a 70 Camaro I did this swap on it was easy. You need the spindles they push the caliper outwards from the center of the rotor to clear the 12" rotors. You have to have the studs drilled for the f-body wheels to fit. Or you can use the 1LE rotors. Just a matter of fabing the PBR calipers to the spindles. I bet it could be done.
I dont know about using the PBR caliper though. I didnt try that..)
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
[This message has been edited by MikeH (edited June 22, 2001).]
Old 06-24-2001, 04:16 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Now you're talking, guys. I have a '70 1/2 split-bumper Z28 that's waiting for me to quit fiddling with my IROC..
I have also seen complete kits in the PST catalog, but who knows what they're like.
Old 06-24-2001, 06:12 AM
ANDYZ28's Avatar
Car: 1982 Z-28
So I guess what I need is a set of 2nd gen spindles,3rd gen 1LE rotors,bearings, calipers, and carriers. Then see what kind of adapter will be required?
Does anybody have a 2nd gen spindle lying around?
Old 06-24-2001, 09:04 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
You might need to use a 77-81 F car spindle for the 1LE rotors to work. The -76 b car spindles had a smaller diameter at the outer bearing surface of the spindle. Im not sure if its the same with the 70-81 f-body or not. Thats why I had to use the 77-79 B car spindles because the 1LE rotors outer wheel bearing was a larger diameter than the -76 B car spindles.
Old 06-24-2001, 07:20 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Thanx,Mike. It looks like I have some serious homework to do. Before I can get the 2nd gen setup right. Thanx,again
Old 12-08-2016, 12:04 AM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
Re: Third gen 1LE brakes on a 2nd gen?
Did you ever do this swap? I have a 1970 and wanting bigger better brakes
Old 12-12-2016, 05:33 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Go to http://www.customworksperformance.net/index.html This is where I got the brakes for my 73 Camaro
1992rs/ss
05-19-2020 07:02 PM
Vintageracer
01-10-2020 05:33 PM
Eagle223usa
Brakes
08-14-2015 09:24 AM
MustangEater82
Brakes
08-11-2015 07:52 AM
THABADGUY
Brakes
08-11-2015 03:43 AM
Quick Reply: Third gen 1LE brakes on a 2nd gen?
