Anyone with Moog Iroc springs 5665s
Old 11-22-2011, 03:47 PM
89rs454's Avatar
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
It has been a year since i have let the car settle with these moog 5665 IROC springs and ive seen no subtle changes in ride height in the rear. My Fuel pump just happens to take a **** so i figured it would be a good time to chop some *** off the rear while i'm at it.
Front
Rear
The front is good but the rear sets up like a 4640 John deer tractor, should i cut a half a coil or a whole coil?
Old 11-22-2011, 04:18 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Anyone with Moog Iroc springs 2665s
I assume you mean 5665. If so, I had the same experience. I'd cut a half and see where you're at.
JamesC
Old 11-22-2011, 04:26 PM
89rs454's Avatar
Car: 1989 SS
James i do mean 5665s and will do, i plan on using the stock isolators if that helps? Thanks.
Old 11-22-2011, 05:05 PM
89rs454's Avatar
Car: 1989 SS
Will post results when i'm done.
Old 11-22-2011, 05:44 PM
JamesC's Avatar
Re: Anyone with Moog Iroc springs 5665s
I dumped the OE isolators in favor of radiator hose.
JamesC
Old 11-22-2011, 06:52 PM
89rs454's Avatar
Car: 1989 SS
JamesC
Then i'm cutting a full coil, i'm not doing that rad hoise trick.
Old 11-24-2011, 09:40 PM
83 Crossfire TA's Avatar
heater hose and not radiator hose. cutting the springs stiffens them, make the back too stiff and you have an unsafe car.
Old 11-25-2011, 10:09 AM
GTA1990's Avatar
Car: 1991 Trans Am
Engine: L31, LT4 hot cam
Axle/Gears: 3:43 LSD
unless you running a sub or otherwise have some weight in the boot, I don't think even a coil lobbed off, and the isolators removed, will get you where you want to be in terms of ride height
See attached pic; I'd say the front of my car is the same height as yours (can get a finger between the arch and the wheel). So far, I've cut 1 and a quarter coils off of the rear of my moog cargo coils and it still has a distinctive rake. I'm running a single 12" and an amp in the boot.
I should mention that with a half coil off the rear and full coil off the front my car handled very predictively and broke in a neutral manner (slight front plow - safe). Now that I've lobbed another 3/4 coil off of the rear, I fear I might have created an oversteering monster!
only the track will tell me for sure...
Old 11-25-2011, 03:38 PM
89rs454's Avatar
Car: 1989 SS
No subs here just good ole fashioned 6x9s car is heavy enough with the chrome 17s. So in all you cut 2 coils off the rear in total and the rear still sets up 1 inch to high? Then again i could live with your stance over mine anyday. I do mean Anything is better then this tractor pull i have setting in the garage even with the saggy stock rs springs set perfect until you gave it gas and it slammed down on the bumpstops so hard i thought my 10 bolt hit the ground.
I'm a smart driver IMO I don't act a fool when i drive, hell i don't even drive my car in the rain or snow. The spring rate offset will be fine with 275hp and 330ft/lbs. Tomorrow i will see what i come up with. I'm starting with 1 Coil maybe half.
Old 12-02-2011, 03:07 PM
89rs454's Avatar
Car: 1989 SS
I like the stance but i still think i need to cut a quarter to half a coil? Opinions?
Old 12-02-2011, 03:20 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
You do need to drop that down! I put new Moogs all round on my previous car and I think I took a coil and a half off the back and a full coil off the front. No 'unsafe' handling issues- in fact it 'stuck like GLUE!' in the corners according to my 8 year-old passenger!
Old 12-02-2011, 03:34 PM
89rs454's Avatar
Car: 1989 SS
Thanks for the tip. Whats funny is The moog 5665 rear springs are 1 coil larger then the stock RS 5.0 springs, and the same coils as 95 Formula rear springs.
Old 12-02-2011, 08:15 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
I ended up cutting iirc 1.5 coils off my 5665s and they were still extremely soft. With half coil cut 5664s up front and a 34/21 sway bar combo the car would no oversteer not matter what you did.
Old 12-03-2011, 03:35 AM
89rs454's Avatar
Car: 1989 SS
Well in my case they are more stiff they still dip but don't squat.
customblackbird
08-15-2021 10:16 PM
Derick15
Members Camaros
08-20-2015 10:19 AM
TA8487
08-11-2015 09:02 PM
mustangman65_79
08-11-2015 03:17 PM
Quick Reply: Anyone with Moog Iroc springs 5665s
