engine miss firing need help
Old 07-29-2006, 01:04 AM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
ok i got my camaro running and i took it out to drive and when i get on it it pops and studders then ittl go and i noticed my number 8 spark plug boot is meled to the header would that be my prob? grounding itself out?
Old 07-29-2006, 01:37 PM
Vader's Avatar
It's a fairly safe bet that it will cause some misfire issues.
Old 07-29-2006, 08:49 PM
Engine: 355
i changed the plug and its still doin it!!! im gettin tempted to sell it dunno what else to do
Old 07-29-2006, 10:19 PM
Vader's Avatar
Changing the plug can't hurt, but it really sounds like you need to check the wires, not the plugs.
Old 07-30-2006, 01:09 AM
Engine: 355
sorry thats what i meant i chnged the wire and its still doin it. carb? timing?
Old 07-30-2006, 10:53 AM
jamessr's Avatar
Car: 92 Firebird
Engine: 5.0L V8
Transmission: 700-R4
Still sounds like a firing issue, what kind of plugs are you using? Hope to G0D its not splitfires. Also be sure and check the gap, should have.035
Keep us posted.
Old 07-30-2006, 07:38 PM
ninabl's Avatar
Car: 87 IROC-Z
Engine: POS 305
Axle/Gears: DUNN0 STOCK DISK BREAK 10 BOLT
UM
I HAD THE SAME PROBLEM AND TOOK THE DISTRIBUTOR OUT THE PLUGS AND WIRES OUT AND PUT IT ALL BACK TOGETHER AND FIGURED OUT THAT IT WAS T WIRES ON THE WRONG SPOT ON THE CAP
DONT SELL IT YOU WILL BE KICKIN YOUR SELF IN THE @$$ LATER
NICK
Old 07-31-2006, 04:15 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
As was said check all the plug wires, check to be sure they are on the correct places on the cap, be sure plugs are good and gapped properly, be sure there is no carbon build up in the cap or rotor, if it stll happens get the ignition module tested.
Old 07-31-2006, 05:07 PM
Engine: 355
k i have the platinum 4 plugs in and they dont get gapped and i have cheap valucraft wores but ran them before and never had issue. so possible on wrong connections then?? wont be the carb or anything else????
how do i test the module?
Last edited by billybob6110; 07-31-2006 at 05:07 PM. Reason: Automerged Doublepost
Old 07-31-2006, 07:25 PM
jamessr's Avatar
Car: 92 Firebird
Engine: 5.0L V8
I would get rid of the platinum 4 plugs. They cause excessive heat , and I'm speaking from experince on thsi one. I suggest get the cheap AC Delco, what GM advises you put in there. I understand you paid $5 a plug, but take it as a lesson learned.
Old 07-31-2006, 10:49 PM
Engine: 355
so it could just be the plugs and wires?? i had a timing chain go out and timed right so im wondering when it went and started to shoot gas out carb if i filed a plug maybe?
Old 08-01-2006, 03:16 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Just pull the ignition module out and take it to O`Reilly`s or Advance auto and they will test it for free.
Old 08-01-2006, 06:52 PM
jamessr's Avatar
Car: 92 Firebird
Engine: 5.0L V8
I still sugest getting rid of the Platinum plugs. I went ahead and bought 6 plugs for my old sixbanger, the temp stayed constantly around 210-220. After takling to a few mechanics I was advised on removing them before I do serious damage. My best advise is do a complete tune up. However I'm willing to bet its your plugs.
Old 08-04-2006, 05:11 PM
Engine: 355
yeah im gna be replacing my cap and rotor on dist. its corrodied badly and theres hott marks on the top of the cap so im thinkin the caps bad. im gna get rid of them plugs cause im running 220-210 right now... thank any other ideas lemme know
Old 08-04-2006, 10:40 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
You're running temp is fine and the plugs, now that you've been boned, should be fine so long as you don't run an MSD or something similar. Will they impede the flame front a bit, sure. Will you notice it. No.
IF you decide to pull that module though, do get the proper compound for it upon intall, iirc SL203 is the wells part number. Thermal heatsink compound. If you can't find that you can go to staples or some such and overpay for the computer stuff.
Old 08-11-2006, 08:22 PM
Engine: 355
got er fixed
the whole prob wa my distributor cap it was junk, orignal cap on car! anyway does anybody know how to take the blower motor of the firewall for heatera nd the a/c(big thing on firewall) off???? and which wires can go and which gotta stay?
Jae992
08-27-2015 09:07 AM
TheExaminer
08-19-2015 10:07 PM
86White_T/A305
08-17-2015 12:16 AM
eightsixseven
08-14-2015 03:09 PM
bradleydeanuhl
08-12-2015 11:48 AM
Quick Reply: engine miss firing need help
