1/2 or 3/4 lifter preload? roller lifters
Old 04-10-2008, 08:09 PM
W72
W72's Avatar
Car: 89 GTA & 92 T/A covertible
Engine: 408LS-SC, 355 TPI
Transmission: 4L80e, 700r4
Axle/Gears: 12 bolt, 9 bolt
Okay, what's best? 1/2 turn or 3/4 turn after zero lash for lifter preload. Or do folks use the factory manual setting of "one full turn" after zero lash.
I've read many threads with references to all 3 but no definitive answer.
Old 04-10-2008, 08:51 PM
Guest
Guest
Posts: n/a
Re: 1/2 or 3/4 lifter preload? roller lifters
1/2 turn is fine.
Old 04-10-2008, 09:58 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
1/2 turn sets the .030" preload in the lifter and will be fine.
Old 04-11-2008, 12:31 AM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Unless you're crutching something, you won't see any difference between 1/2 turn, 3/4 turn, and 1 full turn.
The good ol' boy engine builder fellow racer I talk to who seems to know every cheap trick out there, and not only that but also what works and what doesn't, uses factory roller blocks for his roots-blown 383's, and sets Chevy hydraulic lifters, flat or roller, at 1 full turn down.
Old 04-11-2008, 06:21 AM
W72
W72's Avatar
Okay!! That's what I need to know!
1/2 turn down is it!
Thanks fellas.
Old 04-11-2008, 12:42 PM
SteelTownMadDog's Avatar
I have mine set at 1/3 down with retro-roller lifters. No valvetrain noise.
Old 04-12-2008, 10:37 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
way too much time and concentration involved
get em close
start the motor and wear some good gloves that are made of leather that you dont mind getting oil on
adjust the rocker untill the tip of the rocker has good resistance to you moving the tip across the top of the valve from side to side
what I mean is grab the very front of the rocker arm with your thumb and forefinger and move it from side to side sliding it across the valve
there should not be any play here but the rocker should still move slighly
you will get the hang of it quickly- dont worry the rocker will not jump up and bite you
this will adjust the valve lash perfectly
spray your engine compartment down with cleaner and take it to the carwash
look out for cops before you stomp on it because your engine will be way more dialed in that any other valve lash technique
third gens are the shiznezel
Old 04-12-2008, 12:12 PM
onebad89RS's Avatar
Car: 89 RS
Engine: 305 carbed
Axle/Gears: 3.42 auburn posi
when i built the 350 for my S-10 i set them at 1/2 turn. after i drove it for a week i noticed they started to make noise at higher RPM so i added 1/4 turn and they are now nice and quiet.
Old 04-13-2008, 09:31 PM
2oldFbody's Avatar
Car: old chevys
This will help for max power out put.
http://www.gofastnews.com/board/tech...g-max-rpm.html
Old 04-14-2008, 07:03 AM
squeeezer's Avatar
Car: 5 cars
i have crane factory replacement roller hydraulic lifters
comp magnum rockers with pollylocks
and springs that are up to the task
i go to 0 lash and 1/16 turn
i can go 6500 rpm all day
my dyno guy told me to do this
MoJoe
Members Camaros
31
10-06-2021 06:38 PM
skinny z
10-05-2015 06:23 PM
gord327
10-03-2015 01:25 PM
Agent507943
Firebirds Wanted
10-02-2015 07:18 AM
gord327
09-29-2015 10:18 PM
Quick Reply: 1/2 or 3/4 lifter preload? roller lifters
