fuel relay on 84 t/a??
Old Apr 11, 2008 | 11:57 PM
L69HAWK's Avatar
Car: 1984 T/A WS6
Engine: L69 305
Axle/Gears: fact G80 with GT4 3.73
does my t/a have a fuel pump relay. its a mechanical fuel pump, so it shouldn't have one right?? i am trying to figure out how to hook up my heated o2. i don't want it running all the time, just til it goes into closed loop. i put a simmilar post in another spot on here but did not get the answers i needed. i was directed to search for some old posts by Vader,but all i see is for newer years. i know the 82-84's are different. please,please help me out here. my longtube installation is almost done. this is goin to be the only thing that holds me up.
Old Apr 12, 2008 | 07:34 AM
L69HAWK's Avatar
Car: 1984 T/A WS6
Engine: L69 305
Re: fuel relay on 84 t/a??
please guys. i'm really stuck here.
Old Apr 13, 2008 | 07:14 AM
L69HAWK's Avatar
Car: 1984 T/A WS6
Engine: L69 305
unbelievable.24 of u looked at this post,but no one wants to help.
i appoloize if i seem alittle agitated,but i need to get this done.
thanks again.
jay.
Old Apr 13, 2008 | 08:06 AM
NowTheBadNews's Avatar
Car: 2006 Ford Mustang
Engine: 4.0 V-6
Transmission: Automatic
Axle/Gears: not sure
all 1984 h.o cars had a in tank electric pump. the relay is mounted right by your fan relay by the brake booster.
Old Apr 13, 2008 | 08:49 AM
L69HAWK's Avatar
Car: 1984 T/A WS6
Engine: L69 305
so does it have a electric and a machanical pump. b/c i def have a fuel pump on my block. not doughting u,but why would they put to fuel pumps on it?
Old Apr 13, 2008 | 10:07 AM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
IIRC the L69 cars had an elec in-tank pump to cure a vapor lock problem attributed to the fuel feed line running so close to the exhaust. When you turn on the key do hear anything that sounds like an elec pump? Like Badnews said the relay should be located up in the corner to the right side of the brake booster. Not sure which is which, you'll have to check a diagram or maybe some else who knows will chime in.
Old Apr 13, 2008 | 06:56 PM
L69HAWK's Avatar
Car: 1984 T/A WS6
Engine: L69 305
ok. i'll check tomorrow. i'm right in the middle of doing the motor mounts. so i will be pulling the suspension down. i just never heard of any body putting a mechanical and an electrical fuel pump in a car. not saying its not poss,but damn.that would be weird to me.
thanks guys. i appreciate ur help.
Jay.
Old Apr 13, 2008 | 07:13 PM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
If you hooked the o2 up to the fuel pump relay it would be on all the time.... Why not just hook it back up the way it cam from the factory except on the headers? It should work good that way, and it's probably a cc carb, which means it will advance your timing until in closed loop. That just helps the engine warm up faster.
Old Apr 14, 2008 | 08:41 AM
L69HAWK's Avatar
Car: 1984 T/A WS6
Engine: L69 305
do u think that would work? where would all the wires go. its a 3 wire o2. so 2 white and 1 black. 1 white goes to grnd. i have tyo look at the wire diag on the o2. i forget where they all go.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
Caspar
Jun 19, 2016 11:19 PM
