my turn signal wont shut off!! help
1992 camaro rs with 3.1 v-6 turn signal indicator on the dash stays on all the time and signal dont work. changed bulb in side marker light and still dont work changed bulb in tail light and still not work the right side of the car works fine.. can anyone help with this problem?????
Re: my turn signal wont shut off!! help
thanks i will check the relay, but if the relay was bad then why does passenger side still work? i will check it out anyways and the switch also thanks again
You have a point about the other side still working. It's possible that you have a loose wire on your light socket that's acting as if the bulb is burned out. I'd check out your sockets and wiring first, followed by checking the switch in the column itself.
