Radiator question
Old 05-11-2011, 11:52 AM
jwoodworth90's Avatar
Radiator question
I have a 84 camaro that i just swapped my 355 into. I need a bigger radiator for it and was wondering if there was a truck radiator that had the same design just a little thinker that i could use, any suggestions?
Old 05-11-2011, 05:07 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Radiator question
If the car was a V8 before, the stock radiator should be fine I'd think. I'm running a stock 305 TBI radiator with my 350 and not any problems in last 4 years, even in hot 100 degree summer days. You just want a good fan setup and good temp switch. I myself am actually also running the stock 305 single electric fan as well, but I'm running a seperate fan controller that is adjustable so I can have the fan come on earlier (on at 200, off at 185). And I'm running a 180 stat.
Old 05-11-2011, 08:19 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
use your factory radiator. ive used my factory radiator with my 355 swap for about 20 months now. what i did is, i installed a 160 degree thermostat, and my water temp is NEVER over 155 degrees. Even when i drive the car EXTREMELY hard
Old 05-11-2011, 09:00 PM
After running the car for about 10 mins with fan always on I climbed to 195 and when I rev you can see the lower hose collapsing figgured the radiator was to restrictive.
Old 05-11-2011, 09:05 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
no thats beacuse you need a spring in the lower hose to prevent that. Also 195 is not hot when u get to 230 and higher then its gettin pretty warm
Old 05-11-2011, 10:02 PM
TNT_Z28's Avatar
try a 160 degree thermostat. see where that gets you.
its a very cheap and easy thing to try. i dont think the thermostat and the gasket even add up to 10 bucks
Old 05-12-2011, 09:51 AM
Car: 1992 RS
Engine: Carbed 350
If your running the computer controlled system still, a 160 stat might be too low, and the cooler temps may make the computer richen the mixture all the time. But a 180 stat should be a happy middle.
Old 05-12-2011, 10:42 AM
There is no computer in the car anymore and i already have a stat. Where would i find a lower hose with a spring in it. i was searching online napa, autozone, and even summit but cant find one that says anything about a spring.
Old 05-12-2011, 06:21 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
yea no parts store hose will come with the spring i run a napa and we just happen to have one in a bunch of overstock in the back might wanna see at a local parts store or worse comes to worse u could use a coat hanger but make sure its painted so it doesnt rust.
1992 Trans Am
05-10-2023 07:19 PM
Ron U.S.M.C.
09-07-2015 08:38 AM
Clean87TA
09-04-2015 11:23 PM
redmaroz
08-16-2015 11:40 PM
eightsixseven
08-14-2015 03:09 PM
Quick Reply: Radiator question
