Are motor mounts the same?
Old 05-17-2011, 04:12 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
Hi, I'm in the middle of replacing my motor mounts and I heard something about there being a difference between the two? My new ones have the same part number and I cannot tell the difference between the old ones in my car.
Old 05-17-2011, 04:14 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Are motor mounts the same?
Left and right are slightly different, with different part numbers.
Old 05-17-2011, 04:55 PM
0pyders's Avatar
I was referring to the rubber mounts with the metal shells around them that bolt to the k member. They are different?
Old 05-17-2011, 06:07 PM
lonesomeloser's Avatar
Car: 1983 Z28
I am replacing mine as we speak. They are functionally identical, but there is one small corner that is trimmed from the bottom of the pass and driver side. I guess it makes it more flush against the k-member when looking from above.
Old 05-17-2011, 06:16 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Inserts are the same left and right.
Old 05-17-2011, 07:09 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
i just replaced mine about a month ago. they were identical in every way
Old 05-17-2011, 08:09 PM
0pyders's Avatar
Thanks a lot guys. Appreciate it.
Old 05-18-2011, 05:24 PM
0pyders's Avatar
I just took a look at the metal mount brackets that bolt to the engine and they both say 14037877
So I have 2 right side brackets?
These weren't from my car, they were on a 70's 350 block.
I got these two brackets two fit in the car last time..I'm confused.
Old 05-18-2011, 06:34 PM
TNT_Z28's Avatar
i could be wrong, but i think that gm used the same style mounts for a lot of different vehicals with small blocks.
Old 05-19-2011, 07:31 AM
Guest
Guest
Posts: n/a
I was under the impression that the early '80s Monte Carlo used the exact same 305 mounting as the third gen Camaro. It seems plausible.
But when I ordered my Moroso mounts on Monday, I noticed they listed different part numbers for the late '70s Camaro than for the mid '80s Camaro.
Old 03-18-2016, 08:47 AM
mburdick's Avatar
any one know which is left and right on the engine block
Old 03-18-2016, 09:12 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Here is a picture of the engine " clamshell " brackets,........
E Rod
08-28-2015 05:17 AM
Wesly_66
08-26-2015 09:55 PM
Elliswon
08-10-2015 12:33 PM
NBrehm
08-05-2015 07:57 PM
Quick Reply: Are motor mounts the same?
