alternator problems
Old 07-23-2012, 04:21 AM
jack1005's Avatar
alternator problems
Hi I'm not sure If this is the right thread but anyway my alternator was bad i put a new one in along with a new battery and it still dies when you pull the terminal off I'm not sure if it is wired wrong or what but there is a ground on the alternator running to the negative terminal a smaller red wire hooked to the back that runs to the positive terminal and there are 2 small wires brown and green and i don't know where they hook up I don't know if there is a diagram for the alternator out there or what i couldn't find one any help is appreciated thanks also its a 2.8
Old 07-23-2012, 03:51 PM
BlueWrath92's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 10 Bolt 3.42 Posi
Re: alternator problems
Im not too sure about the 2.8l. I know alot of people dont like Haynes manuels but you could buy one or just go to AZ and open one up and check what the proper connections (they should say).
Old 07-23-2012, 04:12 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
http://www.austinthirdgen.org/index.php?pid=19
norcalz28
Northern California
26
12-07-2016 12:49 PM
middian
09-05-2015 01:42 AM
andy74
09-03-2015 08:41 AM
Hotrodboba400
09-02-2015 07:28 PM
greenyone
09-02-2015 03:39 PM
Quick Reply: alternator problems
