1985 z28 tpi car turns over but will not start
Car: 1985 z28 tpi
Transmission: 700 r4
Axle/Gears: 3:23
Fuel pressure good
New plugs cap roder tested plug wires and coil good spark
It's seems like it is trying but it jjust wont bust off I even tryed jumping with my truck for extra volatge and still wont start ...... tps is callibrated i also installed a fuel pump cut off switch i was told it would help with the flooding issue Please any suggestions this is very annoying I drove the car 3 weeks ago
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: 1985 z28 tpi car turns over but will not start
Did anything change since you last drove it? Blown fuse anywhere?
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Hmmm... I can;t remember what atrocities were commited in the '85 tpi, but if it were any other TPI car, I'd suggest unplugging the MAF and trying to start it. If it does/doesn't, you go from there.
Car: 1985 z28 tpi
Axle/Gears: 3:23
I am about ready to put a carburetor on this thing starting to really hate tbi i replaced pick up coil to still wont run pls help
Car: 1985 z28 tpi
Axle/Gears: 3:23
I don't own a gauge i wish i did but the car is wetting the plugs while trying to start so i figured it had enough pressure ?
Car: 85 Iroc-Z
I would get a gauge to see if your fuel pressure is low or not. Will it start with starting fluid?
NBrehm
08-25-2015 11:49 PM
