Different oil filters.
If I remember correctly & I think the tip came out of the GM Performance Parts Catalog, there was the recommended stock oil filter for our third gens & then there was an extra capacity filter that had the same fit, but held almost an extra quart.
Does anyone have the two AC Delco filter numbers?
Transmission: Pro-built 700R4
Re: Different oil filters.
If you so with K&N, the 3002 will fit our cars also.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
For years I always used the longer filters for the purpose of extra oil capacity and better cooling. I have since changed back to regular length because I am afraid of a puncture through the thin skin of a low flying oil filter.
Car: 1987 Black IROC-Z (SOLD)
I have used the long oil filter with the extra qt capacity. I have never had a prolem with these filters since my car's first oil change 28 years ago. Original owner.
Engine: 4++,350 & 305 CIs
I used to run Delco filters, after loosing 2 motors due to the "new improved" design, I now use Wix racing or napa gold which are still using the good internals.
Old old old numbers were PF25 (short) and PF35 (tall).
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
WIX racing is your best choice for a disposable filter. NAPA Gold is second choice. There's only a small handful of filter manufacturers. WIX and FRAM being a couple of the top ones and they make filters under many different brand names. You need to learn how to identify a filter based on design to figure out who actually made it. Some fancy filter with lots of marketing to sell it may be a crappy FRAM. A lot of house brand filters are made by WIX or FRAM. The WIX house brand isn't as good as the racing version but I'd still buy it before I put a FRAM on any of my engines. AC Delco filters are not the good filters they once were.
I run a System 1 reusable filter on my race car. Take it apart, clean it and put it back on the engine.
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Wix or NAPA Gold- which are the same filter with the same part number... ask for the PF35 equivalent.. they are like $6 at NAPA..
Car: 90 camaro rs
Engine: 409 sbc
Transmission: th350
i use wix racing as well never had a problem for part number just add a r at the end and that is the racing version as some have said on here many made buy same two or three company cheap micro guard filters are made buy wix same filter different name i used to sell them
51069R i believe is the filter i use (wix racing)
Car: 90 camaro rs
Engine: 409 sbc
Transmission: th350
thought i would also mention like alkyiroc did just because micro guard is made buy wix it is not the same as the racing filter they are very different on the inside the racing flow better and filter better
I've been using the K&N longer filter 3002, since I don't have an oil cooler factory or aftermarket so it lines up perfectly with the oil pan and doesn't stick down. The old AC Delco PF25 is what I used to use and was on my factory service manual as the replacement. The AC Delco PF454 is a smaller filter than the PF25 and no way I was going to go backwards.
AlkyIROC, I am not sure I'd run a Racing WIX in everything. For example, with the 51061 the Nominal Micron Rating: 21. Step to the 51061R and the Nominal Micron Rating: 61.
OK for a race engine that doesn't require the durability of a street engine, but I'll stick with the 21 micron for my street car. Would you disagree?
http://www.wixfilters.com/Lookup/Par...PartNum=51061R
http://www.wixfilters.com/Lookup/Par...px?Part=156755
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
This is what I use.
= Mobil 1 Oil Filter # M1-302
= Should be able to buy them anywhere.
I also use Mobil 1 Extended Performance Motor Oil
skinny z
10-05-2015 06:23 PM
