1987 350 TPI crank - no start
Car has been in storage for about 4 years, New gas, fully charged new battery, car hasn't started in about 1.5 years before that i started it every 6 months or so
I have +12 at red coil wire, I have 7500 ohms from Hi point to pins, I have about 0.47 ohms between + and - on coil
I have SES light illuminated when key is on (seems good like ecu has power)
Just cranks and cranks, no spark, don't think injectors are firing as I never smell gas, has good pressure at rail and pump comes on with key
Am I jumping ahead to think it could be the iginition control module on the distributor? Is that something that would just go dead after a year and half of no use. Its been inside and heated but it does get damp in there i'm thinking something corroded ?
Thoughts ?
Thanks guys
Thoughts ?
Thanks guys
Re: 1987 350 TPI crank - no start
If it's sat up for that long, with out stabilizer in the fuel tank, it's a fuel problem. Check the fuel pressure and go from there, but I see a tank drop in your near future.
beachrodder
08-25-2015 08:05 AM
Sanjay
08-12-2015 03:41 PM
