What starter do i need?
Old 08-22-2015, 06:33 AM
Cleotiz's Avatar
Hi Guys / Girls,
I bought this car with a lot of parts not installed.
With it, came 2 diffrend starters: One with 2 long bolts and one with 1 long and 1 shorter bolt.
They are both not working so i am going to buy a new one.
I dont want to damage the cogwheel that is on the engine, so my question is:
What starter do i buy for my 305 ci engine?
Regards, Cleotiz
Old 08-22-2015, 07:06 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: What starter do i need?
The starter with two long bolts, has the mounting holes at an angle to the starter face/house, and is for a 168 tooth flywheel.
The long/short bolt starter, has the mounting hole perpendicular to the starter which is parallel to the face. This is for a 153 tooth flywheel, which is what your 305 has.
To confirm, you can look at the starter mounting pad on the block, and see the holes. Hold the start up into position, and the "wrong" one should not even fit against the flywheel.
Take a look at the picture here.
Old 08-22-2015, 09:15 AM
naf
naf's Avatar
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
For the 153T recommend the starter for a 93-96 LT1, it's a much better and lighter design than the stock starter for a 82-92
Old 08-22-2015, 09:16 AM
Cleotiz's Avatar
Thanks for the help!
Would you by any chance also know which Delco number for the one that will fire up my 305? :P
Thanks! Cleotiz
Old 08-22-2015, 09:47 AM
Cleotiz's Avatar
Thanks man, but actually someone here nearby has a couple laying around so i guess ill go for the one that is stock on there
Old 08-22-2015, 11:02 AM
naf
naf's Avatar
Maybe there's a reason they're just laying around? I mean other than they're probably wore out starters that were inferior to begin with...
Old 08-22-2015, 01:54 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
if it's the stock ring gear on the flywheel, then you need the one with the straight across bolts with one shorter than the other..
if it's got the bigger ring gear, then you need the one with the 2 long bolts that are offset from each other..
3rd gen money
10-11-2019 09:57 PM
Gunner242
12-25-2015 04:49 PM
HoosierinWA
Members Camaros
09-29-2015 12:43 PM
Jlanz55
09-29-2015 08:55 AM
SS-EXPRESS
09-28-2015 09:14 AM
Quick Reply: What starter do i need?
