Schrader valve replacement
Car: 1988 GTA Trans AM
Transmission: 5 speed
Where does one get a replacement schrader valve stem for fuel rail? I left my fuel gauge plugged in all winter, now when I remove it, it leaks
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: Schrader valve replacement
it is exactly like a tire valve stem, so, you can try taking it out, and cleaning it. If not, take it to the tire store nearest you, I would bet they have them laying around. Be sure and get one with a valve that is fuel resistant. (the red plastic valve should be.)
