LT4 hot cam & advance/retard install
Old 10-23-2001, 05:12 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
Hey guys.
I have decided to get a LT4 hot cam to go with my AFR 190s and my SuperRam on my new 357. My question is what are you finding to be the best way to install these cams? Straight up, or advanced.
It seems to me that straight up would work fine. Let me know what works and what doesn't.
'88 RS (originally 2.8)
-350, .040 over, vette alum. L98s, stock tpi.
-305 injectors & chip
-TES headers & edelbrock cat back
-3.73 gears, 700r4.
Best with 2.8-17.4@77mph
Best with 305-15.0@93mph
Best with 356-13.7@101mph
on a 2.050 60 ft.
(Damn the 2.8!)
Old 10-23-2001, 11:54 PM
airdeano's Avatar
probably straight up is the most common install.
Advancing and retarding the cam can move the power band up or down a few hundred rpm. Advance for more bottom end and retard for more top end. It usually takes about a 4-degree change for a driver to feel it. When making these changes, increases at one end mean decreases at the other end.
Some thoughts on choosing the proper cam.
1. Longer rod engines seem to prefer shorter durations and wider lobe separation.
2. Short duration cams with wider lobe separations usually yield much flatter torque curves.
3. Longer duration cams require tighter lobe separation to have any mid-range power.
4. Stock exhaust manifolds or a highly restricted exhaust usually respond well to shorter exhaust duration and wider lobe separation
5. Most unported heads approach 85 or 95 % of peak flow at .400 to .450 lift and do not need or want a maximum valve lift over .540 to.555. Often a low cam lift with 1.65 or 1.7 ratio rockers is very helpful on the intake side as long as lift is kept to about .550. Exhaust is less critical with 1.5 or 1.55 being the most popular.
6. Dyno testing doesn't test drivability or throttle response of the engine.
7. The important numbers on a dyno sheet are about a thousand RPM above and below peak torque and peak horsepower. Peak numbers are for bragging purposes and high peak numbers do not win races.
8. The benefit of high ratio rockers is faster valve movement and the added lift is frequently detrimental in unported heads. It often helps to utilize a lower cam lift with high ratio rockers.
airdeano
Old 10-24-2001, 02:13 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Mine is installed straight up.....
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old 10-24-2001, 09:23 AM
RCR
RCR's Avatar
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
Mine is straight up. Haven't tried any other way.
Old 10-24-2001, 10:25 AM
Car: Damn
Engine: This
thanx guys. straight up is what i was leaning towards.
Old 10-25-2001, 07:08 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
In your car with those heads and SuperRam, straight up is the way to go. But I installed mine 2º advanced because I have the LTR's still, and the cam's peak is higher than the runner's peak. Installing it advanced helps to bring the power band of the cam down a little, and gives it a touch more vacuum, both good things for a speed density LTR TPI.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old 10-26-2001, 08:09 AM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
Get that cam in and get some times for me!
Old 10-26-2001, 08:29 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I just got my new cam. The specs are similer to the LT4 and in the directions it said my cam was already advanced for more midrange and low end TQ. The specs on my cam are 218/224 496/502 112 lsa. With it already being advanced it should work well with my LTR setup.
Old 10-26-2001, 11:29 AM
BobMachus's Avatar
Which cam did you get?
Bob
Old 10-26-2001, 11:35 AM
Stroked-Z's Avatar
Most cams that i am familiar with already come with 4 degrees advanced ground into them. On my 81 Z with my 383, Dart heads, RPM intake, Holley Street Avenger 770cfm, 4:10, 2800 stall in a TH350 would only hit 13.6's on the track because it couldn't pull any mph. I had the cam installed 4 deg advanced on the timing chain. I took it apart & re-installed it stright up. Went 13.400 and picked up 3 mph. Something you should consider. Know your cam before you install it.
Hope this helps
Old 10-26-2001, 11:46 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I got the Comp XR269HR
Old 10-26-2001, 03:13 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
when i installed it into the car t was straght up,however i feel i should have put it 1.5-2 degrees adv. with that intake setup.with the superram straight up is where you'd want it.
87 trans am,gm crate 350(4 bolt mains 10to1),L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,gutted airbox,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,160 fan switch&t-stat,tb bypass,accel supercoil,cap& rotor,slp 3in. catbcak,a/c delete.
SHE IS GONE BUT I KNOW THE GUY WILL GIVE HER A GOOD HOME.
best e/t:
3653lbs./full tank+ driver.
14.10@96.53mph 2.01 60'
Old 10-26-2001, 06:27 PM
Car: Damn
Engine: This
OK good deal, sounds like a majority winner. My last Comp cam was ground with 4 degrees advance also, it went in straight up with the stock intake.
Do you guys know if the hot cam has advance already ground into it?
[This message has been edited by '87FAKE-IROC-Z (edited October 26, 2001).]
Old 10-27-2001, 12:05 PM
Kevin91Z's Avatar
I bought my hot cam used, and when I degreed it, it turned out to be 3 degrees retarded! I was shocked, and measured it twice to be sure. I put in a 4 degree advance key to bring it back.
anesthes
03-10-2016 10:35 PM
sweet_87_iroc
09-25-2015 10:01 PM
1988iroc350tpi
08-14-2015 07:52 PM
anesthes
08-08-2015 09:37 PM
drathaar907
08-06-2015 04:20 PM
Quick Reply: LT4 hot cam & advance/retard install
