runner dent removal kit
Old 05-13-2008, 11:52 PM
tshack's Avatar
Car: 87 Z28
Engine: 89 tpi soon tpis big mouth & tubes
Axle/Gears: 3:43
Any one ever use the runner dent removal kits sold on Ebay? do they work as good as they say. 9% better flow than stock?
Old 05-14-2008, 12:04 AM
brandotron's Avatar
Car: 2002 Camaro z28
Axle/Gears: 2.73 stock, stock, stock
Re: runner dent removal kit
Seems like a good way to get the dents out, but I don't know if I believe the "better flow" part...
Old 05-14-2008, 09:55 AM
APACHE JOHN's Avatar
Car: 1991 Z28
Engine: 350 TPI RAMJET COMING
As long as the dent isn't "sharp" fill with water and lay them in a deep freeze. Might take a couple times for a large dent. Works everytime and it's free. I've been doing it for year with two-stroke motorcycle pipes.
Old 05-14-2008, 11:34 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Can you leave the runner ends open? I see what you're saying there but my first thought tells me that as it froze it would expand up through the openings at the ends of the runners.
Old 05-14-2008, 02:11 PM
Car: 1991 Z28
I've always left the end open. Try it for yourself and then post up the results.
Old 05-14-2008, 02:30 PM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
I just did this last week! I left about a half inch of clearance between the water and the top of the runners. The water froze, and didn't seem to rise at all. Left them in about 14 hours and almost all the dents came out. It worked great, plus it was free! Thanks to Apache John for the tip!
Old 05-14-2008, 02:38 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Wheres farmington AR at? I have 2 that need done and that trick didnt work on them.
Old 05-14-2008, 02:41 PM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
thats a hell of a tip! that should be a sticky on here somewhere!
Old 05-15-2008, 09:45 AM
Car: 1991 Z28
Suburban of Fayetteville where are you at?
Old 05-15-2008, 10:17 AM
Dale's Avatar
Engine: 350 S-TPI
Subs of Little Rock.
Old 05-15-2008, 10:45 AM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
You could also take it to a music instrument shop that fixes & repairs horns. The guy at The Music Center here in my town got the dents 100% perfect in about 5 minutes and didn't charge me a dime (he was a car guy).
Old 10-15-2009, 08:35 AM
68 RS/SS Ragtop's Avatar
Car: 68 RS/SS cnvrt, 92 Z28, 02Blkbrd
Engine: 295hp 350, 385hp 350, 420hp LS1
Transmission: 4spd, 700r4, T56
Axle/Gears: 3.11, 3.23, 3.42
Did anyone measure an increase in the size of the runner when they froze them?
Old 10-15-2009, 06:26 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
i have done it for years. but, forget the water, use Miller light.. Not only does it taste great but its less filling and expands when frozen much better than plain tap. If you want to expand the runners at the same time you have to use duct tape on the ends. As the Miller expands it pushes off the tape to allow the excess to bleed out. The runners gain about 10 thousants inner diameter after the freeze. Do they flow better? I don't know but they look better with no dents. You can also use Mich light or coors light, but, my experience is that the miller has just the right amount of water to malt for my runners taste.
Old 10-17-2009, 07:17 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
https://www.thirdgen.org/forums/afte...s-inc-tpi.html
stalkier
12-06-2015 11:25 PM
Hawkeye1980
08-31-2015 07:09 AM
kyleb24
08-15-2015 08:24 AM
3rdgenparts
08-08-2015 07:09 PM
drathaar907
08-06-2015 04:20 PM
Quick Reply: runner dent removal kit
