cam made me look stupid!
Old 10-18-2009, 02:38 AM
phoenixxx602's Avatar
Car: 1986 z28
Axle/Gears: 3:73
want to put a cam in my 89 lb9 so i went to one and thay starting asking me questions that i couldnt answer!! help me what kind of cam go in this motor? i know its hyd roller but is it flat tap? computer controled?
Old 10-18-2009, 03:13 AM
87tpiz28's Avatar
Car: 1987 z28
Engine: 305tpi
Axle/Gears: 2.73 posi
Re: cam made me look stupid!
Yes, its a hydraulic roller and its computer controlled
Old 10-18-2009, 08:04 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Roller is one type of lifter and flat tappet is another different type .
What they mean buy "computer controlled" is you can only use certain specification cams in cars with engine computers without major changes to the computer tuning.
Old 10-18-2009, 10:11 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Is your cam bad? The lb9 tbi 305 has a very restrictive set of heads and intake. Going more radical with the cam is not that much of an improvement and can sure make a mess of the computer engine control deal. Have you done the common bolts ons? Headers, exhaust, maybe improve the rear gearing?
Old 10-18-2009, 12:25 PM
Car: 1986 z28
Axle/Gears: 3:73
yea its got the headers,exhust,... so y does the computer controled cam 150bux more?? or are thay just ripping me off?
Old 10-18-2009, 12:27 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
a hydraulic roller cam regardless if its computer controlled or not should cost the same.
1984HO
03-19-2021 11:59 AM
junkcltr
08-02-2019 11:12 PM
Cleotiz
01-06-2018 08:56 PM
Orr89RocZ
04-25-2016 08:28 AM
bamaboy0323
09-03-2015 06:07 AM
Quick Reply: cam made me look stupid!
